Question about LaCie (300728U) 250 GB Hard Drive
Lacie 1 tb....... wont mount with disk u tility i get Verifying volume ?disk1s6? Checking HFS Plus volume. Invalid B-tree node size The volume needs to be repaired. Error: The underlying task reported failure on exit 1 HFS volume checked Volume needs repair when clicking on first aid i get "Disk Utility stopped repairing ?disk1s6? because the following error was encountered: The underlying task reported failure on exit"
  • 721 Answers
I'm a pc expert in general, so I'm qualified to try to answer this. I'm working with real limited info here,so if the answer isn't what you thought or somethings missing, just reply to this question again. This time include the make/model of the pc,the operating system type(assuming windows), & the model of your lacie(there's about 1000 or so in 1gb). Here we go, assuming windows? is the os & that this is an external hdd connected via usb. These steps apply to all versions of windows, except nt,98 & 95. To get the system to "see" the drive, unplug the drive from the usb(this can be done with the pc on), wait a few seconds,plug the usb back in. A window should open indicating that windows is installing drivers for your device & another will pop up saying it's ready for use,hopefully. You don't have to use the software that comes with the drive,unless you want to use a security program or back-up software bundled with it. I prefer not use any bundled software as there are plenty of partition & security programs out for free at www.download.com that are easier & do the job better. Also, the tools built into windows vista & 7 are great for installing removeable media. Even xp isn't too bad, but 3rd party software is best for that os. Now that I rambled a bit there, right click "my computer" & click properties. Go to "device manager" & then expand the "disk drives", see if it shows as a logical disk. If not,no biggie, go down to "dvd/cdrom" & see if it showed in there,not likely but I've seen it happen. If you still don't see it,close the windows & re-right click "my computer", click manage. Go to "storage", click "removable storage", it should show up. If not, then in the same menu, go to "disk management", now it's gotta show up here,if not you may have a defective product. Hopefully, this isn't the case & windows does see this drive. If the drive shows up under the "disk management" as a logical drive, you need to click on the drive in the grey area under the white window that shows all the drives, then you need to right click the same drive & hit properties/advanced & make sure the drive is optimized for fast removal, not fixed storage. All that being done,we can now go to "my computer" & right click,hit explore. The drive should be visible. Right click on the drive,hit properties this will show any partitions that already exist & what file system they're formatted in. All you need in a partition with an NTFS partition to store your files in. This is where a 3rd party software will come in handy(Hint EASUS from download.com) or you may be able to download the original set-up software right from www.lacie.com . If your using the entire drive as one partition, skip 3rd party software. Simply right click the drive & hit format,select NTFS as the file system,then check the box for "quick format",all done. You can use the drive now. If nothing I typed worked, then if it's under warranty,send it back ,if not google for a program called "spin-rite" & follow the instructions for creating a boot disk to run before the os loads. This program will try to fix damaged areas of the disk & has saved quite a few drives. I'm not sure if it works on usb drives or not. If not,then power the pc down,get a screw driver, remove the drive from it's enclosure & pysically install it as a slave on the pc. Re-boot with your spin-rite disk in & run the program. Now if it comes up as a S.M.A.R.T. failure, the drive is done. At that point the drive has a bad controller card & you'll never find one. Let me know if that helps. Thanks for using Fixya!
Posted on May 16, 2010
  • paulsolitz May 16, 2010
    I have a imac running v 10.4.1 hard drive is
    Disk Description : SAMSUNG HD103UJ Media Total Capacity : 931.5 GB (1,000,204,886,016 Bytes)
    Connection Bus : USB Write Status : Read/Write
    Connection Type : External S.M.A.R.T. Status : Not Supported
    USB Serial Number : 00E00103CE164 Partition Scheme : Apple Partition Map
    sorry i didnt include this info in my original question.....
  • Pete MacSparran
    Pete MacSparran May 16, 2010
    Mac I'm not great at personally,however my cousin who works with me part time in my business is a Mac wizard. The set-up is similar but not really, if that makes sense. He had a similar issue trying to format a new drive for a Mac laptop, where he was trying to save the guy's info from the old drive & clone it onto the new one,then install it back to the laptop. Well,that's where the similarity ended & the guy lost all his data & my cousin wound up doing a fresh install of the os. I would search the manufacture's site for any solutions. If you can't get anywhere, email Kevin shox88@hotmail.com & he'll get back to you on this. Just tell him pete sent you in the mail. I'll mention this to him later today & I'll post back if I find anything else out.
My MAC G5 disk utility repair cannot repair selected items
use disk utilty from system disk by restarting computer holding down c key then go into disk utility and try it.
Jan 21, 2014 | Apple Power Mac G5 Desktop
Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Jun 07, 2010 | LaCie (301015) 120 GB Hard Drive
My mac is not recognizing my disk from my hard drive
Open Disk Utility (as I'm sure you already have) and select the main partition of the problematic disk on the left side, which should be titled disk1s10. In the First Aid tab, click the "Repair Disk" button on the bottom right hand corner of the window. *Note: If this is the current boot disk, you will have to boot off of the Mac OSX Install Disk by inserting it and holding the "C" key while it is turning on. Select your language and choose Utilities --> Disk Utility from the menu on the top of the screen, then following the above instructions.
May 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
All data has "disappeared" from my 300G usb 2.0 drive.
you can use a software called g parted , you have to make a dos bootable , and then mount volumes to make the drive ready.
gparted will help you... try the trial version .if you dont susceed let me know.
Feb 06, 2009 | Iomega Silver USB 2.0 Hard Drive
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie firewire 400 cannot be read by computer apple Mac g5
Whenever there is an HFS Volume could not be repaired issue, that means that your hard drive's existing volume has been damaged and may not be retrievable. In most cases like this, you would be advised to perform an Erase and Install to correct the damaged directory on your portable HD. However, as I understand that is not what you want to do, you may want to research Mac Utility software like these titles below:
Disc Warrior 4.1
font.f1 {font: 12.0px Helvetica}
(for Macs from Alsoft)
Tech Tools Pro 5.0 (for Macs from Micromat)
Drive Genius 2 - Mac (for Macs from Prosoft Engineering)
These are three of the better hard drive diagnostics, repair and directory rebuilding software on the market for Mac Users. I have used them a number of times as a professional onsite Certified Mac technician and they have helped me to help the customers I assisted many times over.
These Mac Utility software all have a price point of under $100.00 and when you are able to experience just how well they work, you find it is worth the investment.
an HFS volume error is repairable with the right software and these utilities are your best option aside from outright erasing and installing your Lacie HD.
Mar 29, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
My Lacie wont mount its a rugged 250 gig, Was working fine till it got un plugged before being ejected. now will not mount. I can see it in disk Utilities. try to repair but can't the report is :The...
Mount.... sound like you got a Mac... Don't use the Mac sugested fix. The lacie Website has many revovery software options and Third party software is very good at that as well
I would try that first or try to contact a lacie tech and/or a mac tech.
If this is helpful please email and notify fixya. Thanks
Mar 15, 2008 | Computers & Internet
LaCie 160 GB Hard Drive
Always start with the simple stuff so check the disks power supply is actually supplying power. If you're in the UK (and in some EU countries) the plug will have a fuse in it, this is also the case with some modern US electrical devises so check the fuse. If the disk is receiving power, unplug it and let it cool down for an hour before trying again. Have you tried both a disk repair and a permissions repair? Odd as it may sound you can sometimes fix a problem like this by running a permissions repair on your Macintosh HD. Next, if you have any third-party maintenance tools installed run complete maintenance on the system as well as the external disk. If non of this helps run the firmware updater for this drive, you can download it from www.lacie.com/uk/support/drivers/driver.htm?id=10053 even if it is unable to update the drive's firmware this will give you more detailed troubleshooting information, so post the result here.
Jul 30, 2007 | LaCie (300740) 160 GB Hard Drive
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Help with big extreme disk partition access.
Don't know what operating system your using but in Windows 7 and up it's easy to partition any drive even while windows is running.
Go to --> Control Panel\Administrative Tools\Computer Management\Disk Management and right click - set the size.
You can change it any time as long as whats in it isn't bigger than the size you want to make it. I have a 1 TB in this computer and that's how I did it after discovering that my old drive tools didn't work on this.
For any info on this procedure (or darn near anything you can think off) you can always go to youtube for step by step instructions.
Just watch a few first because some people are better teachers than others.
Mar 13, 2017 | LaCie Bigger Disk Extreme 2000 GB Hard...
LaCie (300728U) 250 GB Hard Drive Logo
77 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
