I have a comcast wireless hookup. i have two computers hard linded to the internet. my primary unit is approx. 20 ft. from wireless router. i have a shop approx 11 feet from my primary computer. i"m trying to send the signal to my shop. there is a wall between my primary computer and the one from the shop. i used have signal there before but my router went bad,and i had to replace it. once i get the signal strong in the shop i want to distibute that signal to two stations i also have a 5 port gigabite swictch.
  • Rory Biggs
    Rory Biggs May 11, 2010
    If both pc'a are hardwired to internet, what are U wanting the wireless for? I use a wireless system to broadcast to/through three mobile homes (metal) and it works fine. R U using G router?
  • 326 Answers
Did U use the setup cd for the new wireless?
Posted on Apr 01, 2008
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
Hello, I have a Linksys 2.4 GHZ wireless access point router. Is there any easy way for someone to explain how I go about hooking this up to my main computer so the computer on the first floor will have...
Contact the cable company and tell them you have a router connected to your modem - they will tell your modem to access the router for it to work.
Oct 29, 2010 | Computers & Internet
I'm trying to hook up a second computer in my son's room. Problem - how do I connect the second computer to my Comcast cable router which is a Motorola SB5100 so he can get internet over the cable?
In the picture, it looks like a wireless router. In that case, his computer just needs a wireless card to get the internet. Or, you can hard wire it directly from the modem to the computer, if you don't have a wireless card for the computer.
Mar 12, 2010 | Linksys Wireless-G Broadband Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I had high speed internet installed and have a wired router connected to the primary and secondary computers. the secondary takes a very long time to go on line.i have tripple checked and the hookups are...
Where the two computers connect to the router, swap the two connections, and restart both computers. Now, which computer is the "slow" one?
How long is "long" ? What program are you running to make an online connection?
Are both computers the same CPU-speed? same Operating System?
Oct 09, 2009 | NetGear WGR614 Wireless Router
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
Jul 25, 2009 | Computers & Internet
Trying to install router for wireless
If that's hooked to comcast you can only have one computer hooked up to it, and no modems as they block mac address. If you are a Comcast customer there is a workaround. Turn on your wife's wireless if she hasit, if not get her a wireless card USB is easiest. Turn on sharing on that wireless card and you will be able to access the internet through your wifes computer, and not run afoul of your Comcast agreement. Or request an upgrade to a wireless router from Comcast but your rent goes from $3.00 per month to $10.00!
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
