Question about Dishwashers
Door won't open - Nobel dishwasher (NBFSD/SS)
I have a Nobel dishwasher (NBFSD/SS) and the door won't open. Does anyone have a solution?
  • 9 Answers
SOURCE: Dishwasher door not catching
that is the spring thats gone and will not lock the jaws you need to replace the lock on the door normaly about£5.00
Posted on Dec 06, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
SOURCE: Sparks from the Dishwasher door
I did learn today that this might have been a problem in one of the control plannel board and they might have to change all boards to make sure problem does not exist. It is costly. Might get a new dishwasher in the same price.
How did your problem got resolved. Did you change th eparts. I was told that it won't be safe to use the dishwasher untill it is fixed completely.
Posted on Jun 17, 2008
IFIXALL
  • 868 Answers
SOURCE: squeaky noise when open door
The door hinge spring tension is rubbing .Pull the D/W out atleast 2 feet and open and close the door while looking for the rubbing problem. Please rate this !
Posted on Jul 13, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 | Dishwashers
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Nov 19, 2014 | Ovens
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Dishwasher door won't latch
it is very likely the dishwasher is not levelled correctly or the springs in the door are too tight. Refer installation manual to check dishwasher levlelling and door spring is adjusted correctly. Please provide dishwasher make and model if you do not have the installation manual.
Aug 29, 2012 | Dishwashers
My Nobel dishwasher keeps tripping the circuit breaker. I think it is when the detergent door flips open it shorts the sytem? anybody know what I can do?
Something to try. Get a short HD extension cord and plug the washer in to a outlet just outside of the kitchen and see if a different breaker trips. Turn off and or unplug all small appliances when using washer. Could have a defective breaker. Good luck, best regards.
Feb 01, 2011 | Dishwashers
Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
May 16, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
LG LD-14AT2 SS Dishwasher.
The door frame is bent and will need to be inspected if further damage is done.  It's possible to fix but if the dishwasher frame is bent, then it's a total loss.  The frame is not repairable or are there any parts for it.
Apr 10, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
DOOR ASSY
that particular door (if your model is indeed kemc308kss-- micro/ oven combonation) is not available as an assy you would need to replace the components that are broken indvidually.
Mar 08, 2008 | KitchenAid Architect Series KEMC308KSS...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
