Question about Kenmore Oasis HE 27082 Top Load Washer
Displaying F1 - Kenmore Oasis HE 27082 Top Load Washer
  • 1,998 Answers
Bad control board dont be surprised if after you replace this board that you get another error code the last one I fixed it started with control board then went to the door switch and ended with me replacing the entire motor sensor harness start with control you can find your part at marcone or allbrandsappliance
Posted on May 16, 2010
How do I stop the F1 error even after assessing there is no water in the bottom tray and dried it with hair dryer just in case
There should be F1 on both displays. "If power fails to the bottom tub it will cause the top tub to go F1. Test heater plate." (from the service manual).
If there is F1 on both displays it could be a faulty flood switch or PCB.
Jan 30, 2015 | Fisher and Paykel Dishwashers
Cannot enter bios in the standard way with F2. I believe IDE controller is set to disable
Turn on your computer. If your computer is already on, then reboot it.
You need to see the initial display screen to get into the BIOS.
Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information.
The majority of Gateway computers use the F1 key.
If, for some reason this does not work, then use the F2.
All of Gateway's desktops use the F1 or F2 keys.
hope this helps
Sep 17, 2012 | Gateway GM4019E PC Desktop
Can't display with my laptop using VGA to 3RCA cable
Can't display where on another monitor or tv? Did you reboot the computer after plugging in the VGA Cable. Sometimes you have to hit the FN Function Key + F1 thru F12 to get the image to display. The correct F1 thru F12 key will have CRT/LCD on it or it might have the icon of a display. Press and hold the FN function key then hit the correct F1 thru F12 Key.
Mar 29, 2012 | HEWLETT-PACKARD ProBook Computers &...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
hi there,
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Oct 03, 2008 | Ovens
Kenmore Oasis HE 27082 Top Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
