Question about Garden
Have an old BCS tiller model 201, must be from the 80's. The transmission (clutch?) just slips when it meets light resistance. It sounds like gears slipping over each other. It is probably the sound it should make when it meets serious resistance. Is there an adjustment or other fix?
extroitive
  • 35 Answers
SOURCE: i have a older troy-built tiller (horse), belts slip under load
Remove the Belt, take it to an a Auto parts store and buy a smaller one, the replacement engine may not be exactly as the old one was
Posted on Apr 18, 2009
rockitman187
  • 2559 Answers
SOURCE: 1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
Posted on May 12, 2009
  • 18 Answers
SOURCE: Clutch slipping (only is 2nd gear), on yzf600r
the problem is in the gearbox not in clutch
Posted on Jul 07, 2009
  • 188 Answers
SOURCE: Motor runs but blade does not move. sounds like
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Posted on Jul 17, 2009
  • 541 Answers
SOURCE: transmission slips and reverse stopped working
you need your transmission rebuilt the clutches are slipping
Posted on Oct 05, 2009
Replaced 2 3 sol in trans goes forward in all gears
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
These details will help.
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
Six gear on my 2007 street glide feels like it is slipping the rpm shoots up when i go to pass a car over 65 miles per hour. the 6th gear light also turns off when i accelerate the lights back up after i...
Adjust the clutch and see if it helps. Find the cable adjuster in the clutch cable and move the rubber boot up or down. Loosen the lock nut and turn the cable adjuster in to get as much slack in the cable as possible. Then, take the derby cover off. In the middle of the clutch is the clutch adjuster. Loosen the lock nut and turn the adjuster screw inwards until you feel a resistance. Do not force the screw or you'll bust your inner clutch hub. Back the screw off and turn it in several times to get the feel of it. Turn it in until you feel the resistance and then back off 1/2 turn. Tighten the lock nut and replace the derby cover. Then go back to the cable adjuster and turn the adjuster barrel outwards until you have about an 1/8 inch of freeplay. Tighten the lock nut and replace the rubber boot. See if that will help your problem. The gears cannot slip as your transmission is a constant mesh type design.
Good Luck
Steve
May 30, 2011 | Harley Davidson FLHX Street Glide...
Honda tiller starts, but blades won't move. Oil is fine, no weird smells.
If this is fg100 model could be worn out clutch or broken parts in transmission.
Mar 04, 2011 | Honda Garden
Put tiller in till gear, goes fine for 30 sec and jump out of gear. tine stop. How do i fix it
Try adjusting the linkage or the shifter cable. If its too tight that will happen. I have almost the same one you do. Look at your manual and check out the blow up diagram. there is a way to adjust most models. If not you may need to replace the cable. But...before you do that make sure your cable isn't meeting with resistance somewhere causing it to be too tight.
May 04, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Transmission slips and reverse stopped working
Sep 28, 2009 | 2002 Chevrolet Tahoe
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Garden Logo
728 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
