Question about Plumbing
I have a AO Smith motor model #C48A95A06 attached to a Gould well pump. When trying to start, the motor cycles on and off many times before the motor starts. The pressure switch has just been replaced. What is the problem?
  • 126 Answers
Your axpansion tank is waterloged (well extrol)
Posted on May 17, 2010
Sounds like your start capacitor is on the blink. Replacement is about $10 plus labor. Your labor or the shops labor depending on your skill level.
Posted on Nov 27, 2010
How could I use my 1hp AO Smith C48A95A06 model motor Goulds pump using solar energy instead of grid power alone?
possible run inverter from batteries to convert to AC power make sure enough battery voltage and big enough inverter
Oct 28, 2017 | AO Smith Pool & Spa
How to replace impeller on guolds j10
What is the make and model of the "pump"?
Gould is a motor manufacturer.
The manufacturer of a pump, will use a third-party vendor like Gould, to provide them a motor for their pump. Gould is Century/Magnetek, which is now AO Smith.
BUT...
remove pump housing/volute covered, and access the impeller. Then on the back of the motor you should be able to access the shaft. Lock up the shaft so it does not spin, and then unthread the impeller. Some pumps, especially two speed pumps, will have a locking screw in the center of the impeller. That screw will be counter threaded or backwards thread. It keeps the impeller from spinning off the shaft during normal operation between high and low speeds.
again if we had more specific information, we would be able to assist you better.
Feb 09, 2015 | Pool & Spa
I'm wiring a 220v Gould Century 1081 pool motor does the pool motor need to be bonded in order to get a proper ground
bonding required for safety 1st hot to L1 2nd hot to L2 green to ground or case and bonding wire to lug on case
May 25, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
I have a Whisperflo Eplus 1.5HP pool pump. It has a A.O. Smith motor. the 50MFD 370VAC capacior is bad and needs to be replaced. Is the Capacitior a run capacitor or a start capacitor? Does it make a...
You didn't indicate exactly what AO Smith motor model you have, but most likely it's Capacitor start/run if it doesn't have a switch. The important thing is to replace with the same MFD as the old so you have the same starting characteristics. Here is a great link on AO Smith motors: http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Aug 13, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Plumbing Logo
1,703 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
