Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Not freezing and trim around door is hot - Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
  • 1,998 Answers
The compressor fan in the back is either bound up or not working unplug your machine until you get the new fan if your unable to replae the fan yourslef call a technician if you are use either marcone or allbrands appliance they will mail you the fan to your house hold
Posted on May 16, 2010
Why is my top shelf freezing up so easily
When opening the freezer door on a hot humid day, you allow this hot humid air inside that freezes on very cold surfaces. Cool your home with AC, it will get rid of the excessive humidity to reduce your freezer problem. The less time the freezer door is opened also helps to reduce the ice buildup.
Sep 06, 2015 | Freezers
FREEZER WILL DEFROST AND THAW OUT FOOD. THEN WILL START FREEZING AGAIN IN A COUPLE OF DAYS. THIS HAS HAPPEN 3-4 TIMES IN LAST 6-8 MONTHS. WHAT COULD BE PROBLEM?
seal around freezer door may be warped/old/cracked... or thermostat is not working properly.
Try duct taping door as tightly shut as possible and check around the time it freezes to see if that fixes the problem. If so, the seal (that has magnets so it will seal completely) needs to be replaced.
If that doesn't fix the problem, it could be a faulty thermostat in the freezer.
May 27, 2014 | Frigidaire Freezers
Maytag upright freezer will not drain and water will freeze in bottom. How do you repair Model CFU2046ARW
Check your door/'s are sealing if they leak u will get freezing occurring in the bottom and around the door will have allot of condensation.
good luck all the best . P's always lay liquid bottle on their side as they will cool quicker and be better on electricity.
Apr 04, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jun 19, 2012 | Sub-Zero Freezers
The edge of the wall between the freezer and fridge is very hot
This is normal. There is an electric, (mullion), heater behind that surface that keeps condensation from forming. It also keeps the freezer door gasket from freezing to the surface and ripping when the door is opened.
Jun 01, 2012 | Whirlpool Freezers
True freezer T-35F. outside the door around the seal is too hot. it took a long time for new food to freeze or not frozen at all. fan seems to be running.
You have check if the fan underneath is running? Or maybe it is starting to go bad and only runs sometimes and sometimes it does not?
May 28, 2011 | True 35 cu. ft. / 991 liter Commercial...
The temperature is increasing and even when put on 'super freeze', the temperature is not increasing just slowly increasing. The model number is 7462SNH1 Please can you give any idea of a fix. A couple of...
fully defrost unit with door open.do not use hot water.
load up with cold food and switch on the unit will take upto 24hrs to reach normal.poss cause ice around coils ...
Feb 11, 2010 | Freezers
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
343 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
