Question about HP Pavilion dv6000z Notebook
The keyboard is not responding to commands - HP Pavilion dv6000z Notebook
    Sergeant:
  • 245 Answers
Its damaged,, use external keyboard when using it at home, it will help increse life of your key pad, you need to go to , service center
Posted on May 16, 2010
  • AYURVEDICC MEDICINE MANUFACTURING
    its damaged,, use external keyboard when using it at home, it will help increse life of your key pad, you need to go to , service center
When I type on the keyboard there is no response... the letters and commands do not respond. In addition, my mouse sometimes does not respond... I have to click on an item 2 or 3 times before it...
did you get any water damage on this? sounds like the keyboard top had a short. you can replace it with a top case from ebay for around $30 dollars.
does it work with a usb keyboard/mouse?
Mar 12, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I connected my Casio CTK 496 to Fruity Loops DAW. I am unable to send CHORDS and note duration information to the DAW. If i press a note, while the Keyboard is connected to my DAW, my DAW outputs the...
Oh, oh... that is often called the "Dreaded MIDI Drone".
There ccan be more than one causes, however two of those are this:
1. The receiving device either does or does not respond to the note off command or only responds to the note on command with zero velocity, which is also now interpreted as note off. Check the MIDI implementation chart to determine this.
2. Two MIDI commands have merged without using a MIDI merger which makes sure ONLY complete MIDI commands are sent. If the commands are mixed, dreaded MIDI drone is assured.
Sep 07, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
I have keyboard and mouse does not work and usb port too
Does the keyboard respond upon system boot. It should.
Press F8 repeatedly until you come to a black screen with text and select command line with safe mode or command line depending on the type of operating system you have.
If it is Windows XP, type in the command prompt: c:\windows\system32\restore\rstrui.exe and restore windows to a time when it was working properly.
If it is Windows Vista, type c:\windows\system32\rstrui.exe.
Jul 25, 2009 | Computers & Internet
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Toshiba 310CDT / Name the Command Interpreter !!
If you " \ " not work, type type ALT + 0 9 5 on keypad.
095 is ASCII code for " \ "
Oct 27, 2008 | Toshiba Astaro Z310 Server
Keyboard not responding after bio check
THE CONTACT PINS ARE GONE BAD..........
TRY SEE ITS BEND AND U CAN FIX IT WITH CARE....OR ELSE ON OTHER OPTION AS IT LOOKS THE KEYBOARD HAS GONE U/S...........
Apr 28, 2008 | Computers & Internet
Computer will not respond to any commands
Make sure that the keyboard and mouse wires are plugged in the appropriate ports, if it still won't work, try switching keyboard and mouse. If it still will not work I would call the factory and try to have it shipped back because it could be blown ports.
I hope this helps some.
Apr 02, 2008 | Compaq Presario 5000 PC Desktop
HP Pavilion dv6000z Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
