Question about Achiever CCS5000 Shredder
Paper feed wheel/gear stripped. Need replacement.
  • jrand1970 May 16, 2010
    Thank you for finding this part. You were very helpful.
Click on the link below to view a replacement gear wheel for your Achiever CCS5000 Paper Shredder:
http://shop.ebay.com/i.html?_kw=Achiever&_kw=CCS5000&_npmv=3
http://www.fixya.com/support/t3887924-require_replacement_wheel
Posted on May 16, 2010
Receipt paper does not advance.
You need to replace the feed gear or roller. Or please call a qualified tech.
Mar 10, 2015 | Retail Supplies
Canon i70 printer clicks when paper is loading
Joseph,
I have the same exact issue with my Canon I-70. I like to attempt to fix things on my own so I opened it up and discovered that one of the main gear wheels that operate the paper feed rod is cracked. I am not sure if it was always like that (I doubt it), but the whole gear wheel is cracked so the gear teeth have separated a bit. When the printer attempts to feed the paper the gear turns and when the cracked side where the teeth are separated hits the other gear connected to it the misaligned teeth do not allow it to proceed. Honestly it looks like a very simple change of the gear wheel will solve the issue. My problem is that I do not know where to buy this piece.
Can someone help me to find the specific gear wheel?
Jun 04, 2012 | Cannon i70 Printer
When paper is fed into the auto sheet feed the left side of the paper feeds, but the right side is not feeding at all....resulting in a paper jam. You can hear the printer printing but the paper doesn't go...
helpful to know what kind of machine you have :\. In general one of the paper pickup roller pads is probably rotated 180 degrees out and not touching the paper, many rollers are triangular/square and have to be oriented correctly. Other causes are the plastic gears which if stripped means a junk printer unless its an expensive one. Stripped gears because someone pulled a jammed page out too violently is the usual cause. Check also for embedded staples/paperclips in the mechanism.
May 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP OfficeJet J6480 Feed gear assembly needed!
Check on www.partsurfer.hp.com it will tell you if the assembly is available, if not on HP site you will need a used unit to get parts from.
Jan 19, 2010 | Office Equipment & Supplies
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
THE DRIVE GEAR FOR THE PAPER TRAY IS BROKE
The gear drive is located in the paper tray lift motor assembly. The gears teeth strip away with wear and tear and can no longer lift the tray to feed paper. Replace this assembly and not just the gear.
Oct 14, 2009 | Ricoh Aficio MP 161 Black and White Copier
Paper feed jams continually. I hear a repeated clicking sound at the time of each jam like the paper is trying to feed without success.
sounds like tthe first time it jammed power was on and someone pulled agains the tide forceing the removaly and stripping the transporter gears. Need to look inside and see if there is plastic gears looking stripped
Jul 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
When I press print, the printer tries to take the paper, but the roller/wheels do not come down and grab the paper. Therefore, the printer says out of paper
if the paper fed rollers do not drop onto the paper it is possible the cam is jammed.
turn the unit off remove the paper and try to pull the paper fed arm downwards and try turning the rollers counter clockwise also.
if the arm drops power back up and retry a pcl command if not you may need a technician to strip the unit and adjust the cam gearing or solenoid action depending on the feed and separation capabilities
Jun 23, 2009 | HP PSC 1600 InkJet Printer
Paper jam is showing on printer info., but ther's no paper jam.
Ok this issue ussually occurs when the roller feed doesn't load the paper due to the following reasons:
1. If your printer is operating for  more than two years or so... gear tear will most likely to occur. If you can open the printer and check everytime the printer initiates after power on ad if the roller feed doesn't rotate but the leftmost rotary gear with the encoder wheel rotates, the gear is most likely to be loose even there is no paper jam nor dust contamination on the rubber and paper feed mechanism. You need to replace the said gear with the encoder strip . A simple solution would be aplying epoxy resin so it will be fixed on the rotary shaft. It may last for quite sometime but better yet replace the gear.
2. The feeder rollers might be dirty and needs to be cleaned and greased the gears.
3. Probable defective print cartridge. Try replacing it with a new one.
But based on the items above, if your printer is operating more than a year or two, and frequent paper jam is being experienced, gear tear near the motor is the culprit.
Dec 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Achiever CCS5000 Shredder Logo
124 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Gilbert Ruiz
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
