Question about Acer AL1916W 19" LCD Monitor
The monitor only has blue green & yellow color The model is AL1916W & is only a couple of yrs old
  • 11,361 Answers
Please check the pins at both ends of the VGA cable first, also try it on another PC.
If it still does the same then you will need to open it up to inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 16, 2010
The color on my screen is horrible you can't figure out the colors like yellow and green look the same blue and purple also look the same
Is your video card working correctly? Does old monitor (or borrowed monitor) have the correct colors? Did you download the latest drivers for this unit?
http://www.aocmonitorap.com/middleeast/monitor_198.php
Apr 13, 2011 | AOC 917Sw 19" LCD Monitor
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
The color pallet changed to blue, green & yellow, how do I change it back? model f1703
try to reset your monitor. just press the menu button to open on screen display, theres an option that says factory settings, choose that option and choose yes to continue..
Sep 12, 2009 | Computers & Internet
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Only yellow,blue & green colors, occas hint of red. What are correct settings? middle of gauge,
sounds like degausing circuits bad. unplug for couple of hours. if this doesnt work try waving a heavy magnet in front of tv about 2-3 inches from screen.
Jun 01, 2009 | Philips Magnavox MT1905B 19" TV
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
My Monitor al1916w the color is all purple or blue. No other color appears including white,yellow or red. please help.
TRY MONITOR ON ANOTHER SYSTEM TO MAKE SURE ITS NOT THE VIDEO CARD . IF IT DOES THIS ON ANOTHER SYSTEM REPLACE THE MONITOR, IF IT WORKS FINE REPLACE THE VIDEO CARD IN THE COMPUTER
Aug 11, 2008 | Acer Computers & Internet
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
