Question about Dell Vostro 1510 Laptop
In the keyboard status light there is a 9 on, how
In the keyboard status light there is a 9 in a blue let on, how can i turn off+
    Problem Solver:
  • 12 Answers
Numlock key
Posted on May 16, 2010
9 status lights
I'm not sure what you mean 9 status lights. Each computer case has lights and can be very different depending how it's configured. The owners manual should in detail tell you what the lights mean. Are you talking about lights on the computer case or the motherboard
Jul 17, 2014 | Gateway Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
What is does the blue light with the 9 in a lock above the keyboard mean. and how do i turn it off. dell latitude e5510
9 in a lock light:
Turns on when the numeric keypad is enabled. Turn NumLk off by toggling the key.
You can change it in System Setup. Under Post Behavior heading.
Press to enter System Setup and make changes to user-definable settings. If you have trouble entering System Setup using this key, press when the keyboard lights first flash.
Use the checkbox to enable / disable the Num Lock LED when the system boots.
The factory default setting is Enabled.
May 21, 2011 | Dell Latitude E5510 Notebook PC
Hi my dell vostro key board has locked ,right hand side of keyboard blue light with a lock and 9 inside it .tried everything can you help
The 9 lock key means that your Number lock key is on. The blue light usually means that your blue tooth is on. Try connecting an external USB keyboard to see if it functions normally. If so then you need to have your keyboard replaced.
Jan 09, 2011 | Dell Vostro 1500 Notebook
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
What do the activity lights on the keyboard of the Dell Laptop C640 represent?
To the right of the power button and below the Dell AccessDirect button are three lights. These have a lock synbol below them. The first one from left to right is signified by a number 9, this light is turned on when the numberical keypad is enables. The center light is signified by a letter A, it is on when the uppercase letter function (Caps Lock) is enabled. the third one, far right, signified by a down arrow, is on when the scroll lock function is enabled.
The device status lights on the far right side near the front of the laptop case. The top light is the power status light, the middle light is the Hard drive activity light, the bottom light is the status light for power management, battery, AC etc.
Oct 17, 2009 | Dell Latitude C640 Notebook
"[9]" labeled status light blinking and no display
open the case then locate the memory and make a clean all pin connectors of memory using a paper eraser..
Jul 08, 2009 | Dell Vostro 1510 Laptop
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Status light on upper right illuminated - how to turn it off?
Initially, have you checked/pressed on the "Scroll Lock" key (between Print Screen & Pause). To my knowledge, on most keyboards, the three common indicator lights are: Num Lock, Caps Lock and Scroll Lock.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Ingram BTC-5199 Keyboard
Dell Vostro 1510 Laptop Logo
949 people viewed this question
Alun Cox
