Question about Canon PowerShot A540 Digital Camera
Memory Card Error Card locked. I get the same
Memory Card Error Card locked. I get the same message on more than one known good card.
  • Canon Master
  • 4,738 Answers
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
Posted on May 16, 2010
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
How i can unlock my 2gb sd memory card password
For Nokia S60 3rd Phones, Nokia N-Series and Nokia E-Series
There is almost no way yet known to hack the memory card password in case of these types of phone but there is a way to do it some of the s60 3rd edition phones and almost all the E-series phones.
The remote lock option in E-Series phone allws you to unlock your phone by sending a sms.
The only thing you have to do is to activate this feature by going to Tools | Settings | Security | Phone and SIM | Allow remote lock menu. The password of your memory card will be your remote lock message.
So you have to just send a sms containing your remote lock message that will automatically change your memory card passsword.
Apr 26, 2010 | SanDisk 2GB microSD Memory Card
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Canon PowerShot A540 Digital Camera Logo
337 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
