Question about HP Vs17 17" LCD Flat Panel Monitor
I have no sound from this monitor Have tried other speakers on the cpu they worked good
  • 11,361 Answers
Windows vista My built-in monitor does not sound, I tested w other CPU and it sound
You have to plug the speakers into the computer to get sound out of them. The CPU has nothing to do with the speakers, Also your monitor does not have inbuilt speakers(according to the manufacturers website.)
Feb 27, 2013 | HP W2207h 22" Wide Lcd Flat Panel Monitor...
The speakers on the front of my HP w17e monitor used to work, until I connected seperate speakers so I would not blow out the monitors. Today I did not plug the seperate speakers in, and I can't get...
Check the audio jack plug from monitor to cpu if connected correctly. The audio jack plug should be connected to the sound card for audio out. You can also check if the volume in the monitor is adjusted or mute
Jun 27, 2011 | HP w17e Monitor
I am unable to get any sound from the monitor speaker. Cord is plugged into back of monitor and into cpu. Checked sound settings on Control Panel; made sure mute is not on. Ideas??
Try feedin it with another sound source such as MP3 player, if you do not get the sound, then the amplifier module may have failed and you will be better of spending money on a set of powered speakers instead of trying to get it fixed, you will get better sound any way.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 10, 2010 | ViewSonic VA1912wb Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
I have an acer cpu connected to my hp monitor with built in speakers...but I have no sound?
That is a common problem. You need to purchase some new speakers from your local Radio Shack or computer store.Plug them into your cpu. Very cheap fix about $10. The mix and match connection of the HP and Acer never seems to work. The HP monitor will work with the Hp computers but not others.
Aug 15, 2009 | Acer (90.18612.36B) Computer Speakers
My monitor speakers are not working name of my monitor is Spectrum 9 GIrsA or GlrsA could you help me locate the problem . I know tht the speakers work ,because when I hook up another cpu the speakers...
check if you have installed your sound drivers and the monitor drivers , if they working good on other cpu that should fix your problem. if you don´t know how to check or update drivers let me know. and good luck
Jun 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Green cable connects to hard drive but not to monitor
connect the separate speakers to cpu slot provided and adjust the sound with utility
Mar 21, 2009 | Audio Players & Recorders
Sony mfm-ht75w no speaker sound when in computer mode
go into your computer and find the speaker control
it may be turned off or reseted
Jan 31, 2009 | Labtec LCS 1040 Computer Speakers
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
HP Vs17 17" LCD Flat Panel Monitor Logo
62 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
