Question about Crane Hello Kitty Humidifier
Very little water left/ fills up and leaks
When our hello Kitty Humidifier is almost out of water in the water container, it seems the 'sensor' in the base part of the unit gives up and lets all the remaining water in, which causes the water to leak out of the top of the base (between the base and where the tank fits in). At that time it doesn't spray any mist and the unit and the water get hot. Suggestions?
    New Friend:
  • 15 Answers
**With the unit unplugged**
the float sensor is probably getting sticky with residue and buildup (lime, grime, etc). Try cleaning the little float and that area. It should move easily when clean.
Posted on Dec 22, 2009
SOURCE:
Humidifier model 758.743303. How many gallons of water does it hold? Needing to put water treatment in my water don't know how much water it holds.
Use a container of known capacity, e.g., measuring cup or milk bottle, to fill the humidifier. When full, you can estimate capacity.
Jan 24, 2017 | Humidifiers
Humidifier is leaking where the top meets the base. How can I fix this?
The humidifier may be reacting to being overfilled. A little less water fill may cure the problem.
Jan 06, 2016 | Air Innovations Clean Mist Ultrasonic...
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
Humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Feb 01, 2010 | Crane Humidifiers
Leftover water in the base was hot in the morning
If there is not much leftover water, you don't have to worry much about it. However, if the leftover water is
somewhat flooding the area where it was located, it is a
different story, there is a leak and it must be corrected.
Check for leaks in the water container, so that operates
normally. Hope this will help you.
Jan 10, 2010 | Kaz 5520B Humidifier
I have had my Hello Kitty Humidifier about a year and a half. I have been very pleased, but yesterday it stopped working. It puts out steam, but not enough to make it out the top. It kind of bubbles down...
sounds like the fan in the bottom does not have enough space. make sure the humidifer is on a flat hard surface. If its on carpet or other soft surface the fan can't push air out and the vapor won't come out.
Dec 02, 2009 | Crane Hello Kitty Humidifier
On/Off function
the kitty will turn off if you rotate the dail all the way to off (straight up). Look at the pink arrow on the dial. You will feel that the knob does not want to go any further when you are at "on" which is the lowest setting and no steam comes out. But you have to go all the way to off.
The elephant and frog models have actual on/off switches but this one its just the dail.
Apr 21, 2008 | Crane Hello Kitty Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Crane Hello Kitty Humidifier Logo
335 people viewed this question
Top Crane Humidifiers Experts
gggg
STEVE
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
