Question about Kenmore 63942 Dryer
Kenmore Dryer #63841
One day our dryer just suddenly started making this loud knocking noise. It sounded like it could be out of balance or something. I pulled it apart and found a 1 inch part of the belt that had lost it's rubber. I thought maybe it was that so I ordered the replacement kit. It came with the new belt, both wheels that the drum rides on, and a new tensioner pully. I installed all of those and the sound was still there. Then I pulled the cover off the blower and found all kinds of stuff (combs, pencils, pens, nails, mass amounts of lint) so I thought that might have been it. It is still making the same original sound. Any help?
  • 943 Answers
Thanks for the question If you found all those things iwould also check the felt around the back of the drumthat just could be the problem you can just look inside the drum to see this thanks for the question The appliancedoc
Posted on Sep 11, 2008
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Dryer suddenly started making a loud banging sound like a washer out of balance. The drum still turns. I have disassembled the dryer and the belt looks ok and the rollers seem ok. It was very sudden onset....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 24, 2011 | Dryers
Dryer is making a loud screeching sound
heatman101
Asker
Jan 05, 2011 | Kenmore 800 7982 Dryer
Dryer makes loud noise when on...like drum is banging on something. Purchased April 2009 so not covered under warranty. What can I do to fix problem?
heatman101
ggra
Aug 30, 2010 | Kenmore 600 6965 Electric Dryer
My kenmore dryer is vibrating and making a loud noise, and today it suddenly quit getting warm...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 20, 2010 | Kenmore 62602 Electric Dryer
Kenmore 600 Series Gas Dryer, about 2 years old. Makes a loud scraping or rumbling sound as drum turns, not constant but in a cycle, as if off balance. I checked to be sure it is level. What are the likely...
It is normal for the dryer to make sound due to the high velocity of air moving through the dryer drum and exhaust system.
A clicking noise may be the timer advancing.
Check the load for objects such as coins, nails, etc. Remove promptly from dryer.
It is normal to hear the dryer gas valve or heating element cycle on and off during the drying cycle.
The dryer should be level and installed on a solid floor.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Kenmore 63942 Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud dryer
  • it sounds like a bad roller. if you know how to take the drum out of the dryer then you can do this repair. no special tools are required.
  • you can get step by step (with pictures) instructions at this site.
  •  www.fixitnow.com
Jul 02, 2008 | Kenmore 72982 Gas Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
