Bugera 333xl every few seconds there is a loud buzzing. from
Every few seconds there is a loud buzzing. from bugera 333xl amp worked perfect 10 min and then started buzzing
  • 17,130 Answers
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
Posted on Jul 24, 2010
Where can I get a schematic diagram of the Bugera 6262 Infinium Guitar Combo Amplifier?
Bugera - MUSIC Group
https://www.music-group.com/brand/bugera/home
Notice of Scheduled Maintenance. This is to advise you that our system will be unavailable on Saturday, January 9, 4PM - 6PM, SGT. Please plan accordingly.
Page 44: Bugera Users' Militia (for all things Bugera) @ Ultimate ...
www.ultimate-guitar.com/forum/.../index.php?t...
Ultimate Guitar Archive
Aug 17, 2011 - 100+ posts - ‎68 authors
I really like the cleans on this amp, and I don't consider using the overdrive.. so better tubes will ..... Its a 6262 212 combo ... 6262-212 INFINIUM 10/06/2011 ..... is there aschematic for this mod somewhere floating around? Page 48: Bugera Users' Militia (for all things Bugera ...
100+ posts
Jul 15, 2013
Bugera TriRec - First pricing (US) @ Ultimate ...
100+ posts
Apr 19, 2010
More results from www.ultimate-guitar.com
Rig-Talk • View topic - Bugera Amplifiers
www.rig-talk.com/forum/viewtopic.php?t=138566&p=1605914
Jun 14, 2013 - 50 posts - ‎12 authors
Jan 11, 2016 | Bugera 6262-212 Infinium Guitar Combo...
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
I would like a wiring diagram for Bugera 333XL footswitch.IE the plug connections.
intel d865gvhz i have install but beep sound continuly is there but what problem this is
Apr 02, 2011 | Computers & Internet
Bugera 333XL Amplifier does not power up. Valves do not light.
Steve,
That's a nice amp head.... If it is still blowing fuses, you've got a dead short somewhere, that probably is in the power supply section. The power supply is solid state, (diodes for the rectifier), so either one or two didoes went bad or one of the big filter caps shorted out. Look for a blackened area around these components. Sometimes the caps will have just a "puffed-up" look to them, but.. BE VERY CAREFUL! Some tube amplifiers do not have bleeder resistors on the caps and they can hold a charge of up to 450 volts... Very dangerous! AND can KILL.
If you don't know what those components are, or how to use a volt/ohm meter, you should take it to a technician.
Aug 03, 2009 | Behringer Audio Players & Recorders
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
386 people viewed this question
 Grubhead
Grubhead
