Question about Fisher and Paykel 24 in. DD603MFC Built-In Dishwasher
ERROR F5 - Fisher and Paykel 24 in. DD603MFC Built-In Dishwasher
  • 1,998 Answers
F5 LED's o o @ o @
Lid actuator is jammed either up or down.
Primary Action
- Check for dishes preventing lid from closing.
- Check lid actuators in diagnostics.
- Check yokes are moving freely and are not jammed at the front or rear.
Secondary Action
- Replace lid actuators.
Tertiary Action
- Replace controller.
Posted on May 16, 2010
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Have a Kenmore 110.2632410 top load washer. Getting error code F5. Lid lock is just clicking.
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Jul 17, 2016 | Kenmore Washing Machines
Keb inverter f5 error e.pu
General powericon1.png stage failure.
Most likely will need to replace the power stage or inverter.
Oct 03, 2013 | Inverter KEB COMBIVERT F5
When I reload my F5 5100 I get the following message "hard error: sector 1019072 status 51 error 14: bad format"
Hello my friend, it refers to your hardware components. The error is on your hardware system it causes either the hardware itself where it has a error in the area of SECTOR 1019072 where its status is bad format or its the format of one of your system inside your hardware.
Thanks
Jul 30, 2009 | F5 Networking (f5-big-5110) 24x10/100 Mbps...
F5 Error flashing
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
Apr 24, 2009 | Sharp AL-1642CS Copier
F5 error
HI. I have researched this fault code and this is what we came up with.
F5 Board failure Replace control board (also called ERC or clock).
Mar 21, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Dishwashers Logo
423 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
