Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Water goes into bottom tray
Water does not come out of expresso but goes into bottom tray
  • Krups Master
  • 1,711 Answers
One possible problem is to try to clean the group shower which it can be ansrew by one center screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Both the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
One other posibble problem is the vibrating water pump. It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Posted on May 16, 2010
I live in an apartment. first there was a weird smell when the heat goes on. Now we have the cool on and the water keeps dripping out of the bottom vents and lines around the closed covers.
Water will always be present inside the unit, this is normal. But if you don't clean the tray, dirt and lint can clog up the hose that takes the water out. Look around for a small hose or pipe attached to the bottom of the tray
May 08, 2016 | Heating & Cooling
Model RF267ABBP water standing under drawer
Most likely cause is the evaperator tray has frozen over. This causes the tray to overflow with the defrosted ice every time it goes into defrost (every 8-12 hours). You can start by pulling off the back wall inside of the freezer,and inspecting the evap tray. You will need a phillips screw driver and a flat head to do so.
Jan 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
My Kemore refrigator is leaking water from bottom,I keep moping and I put news papers under to absorbe the water.where is the water leaking from ? Its about 8years not sure, but never a problem.It has a...
Under your fridge, there is a drain hose which goes into a removable tray on the bottom of your refrigerator.This is where the water from the automatic defroster goes. The heat from the motor dries the water up, but occasionally the hose becomes plugged, or does not set into the tray. You may have to pull the fridge away from the wall, go behind the fridge, get down on the floor, find the tray, in the front or back, check that the hose is in place and patent. If the tray is full of water, there may be a heating or evaporating element that is not working to dry up the water, in which case you could always manually empty the tray till you you find a solution. Good luck.
Jun 20, 2011 | Kenmore Refrigerators
Does steam tray/lid go on top or bottom of rice cooker?
The steam tray as you call it goes on the inside bottom of the cooker. It's purpose is to keep the cooking rice separated from the heating element during the steaming process. The basic measurement is 2 parts water to 1 part rice. Add a quarter cup more water for brown rice. The automatic shut-off won't turn off until the water is gone. It's magic! Cleaning; soak the cook pot and perforated plate to remove rice goo DO NOT USE STEEL WOOL PADS or abrasive cleanser. I use a nylon dish cleaning brush to remove the stuck on brown material.
Mar 14, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
411 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
