Question about Refrigerators
Can a refridgerator fit snug or does it have to have air flow?
  • 1,998 Answers
In my many years of fixing appliances many people have asked me this question and yes it can fit snug if you make holes so it can draw air into the side of the cabinet if your fridge cannot get air to cool the compressor down you will cut the life expectancy of your compressor down drasticly. As an option i find it is alot less costly to drill a couple holes down the bottom of the cabinetry or on your flooring behind the fridge then replacing a whole compressor hope this helps
Posted on May 16, 2010
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
Pcv valve removal
follow the air flow from the air cleaner box to the motor.
Sep 19, 2013 | 2006 Ford Taurus
Where is the fitting to refill the air conditioner. The suggested hose onlly fits one fitting and will not serure itself. Please advise,
i would suggest taking your tahoe to a certified air conditioning specialist, the problem may not be that it low on refridgerent and there are legal risks if you get caught releasing any type of refridgerent into the atmosphere.
that said, if you still want to do it yourself, look for the fitting closest to your condensor, it should be the low pressure side connection, and intall the refridgerent as a gas only, turning the can upside down to make it go faster would introduce liquid into your system at the wrong place and cause your compressor to lock up or break.
hope i was able to help you, good luck!
Apr 03, 2011 | 2001 Chevrolet Tahoe
Hummer 2 air compressor pick up and cut off after few seconds
The a/c system is either low on refridgerant ,or the system is retricted and stopping the flow of refridgerant.
Feb 25, 2011 | 2004 Hummer H2
Makita MAC5200 Compressor. Leaks air around the regulator screw in adjustable black knob only when I turn up the regulator pressure to allow air to flow through to the quick connects. I've taken the...
There are two types of regulators used. One has a rubber diaphram sealed at perimeter with body and a piston type. Most likely you have the piston type. Remove body containing piston/ spring mech. Examine piston lip seal. Lip will face toward body of reg. and must fit snugly into cylinder. Make sure cylinder is smooth and is well lubed.
If seal/piston fits loose remove seal and wrap some teflon tape in groove and re-install lip seal /test for snug fit. Notice small metal actuator extending from center of reg. , if it is circular (about 1/8 dia) then there should be an oring of the same size mated/fit into the piston. If this oring is missing it will leak as you describe. Lastly, there should be a gasket or oring sealing outer shell to body. If you have diaphragm type look for holes, tear or shrink too small. Parts are at www.toolpartsdirect.com or Lowes in the plumbing department good place for orings and silicone lube. Good luck
Sep 27, 2010 | Makita MAC5200 Electric Powered Air...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Refridgerator cooling air flow direction.
Hello , this is the correct direction for airflow and its why there is always dust buildup on the cardboard panel. Let me know if you have any other questions.
Phil
Jan 02, 2009 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
