Question about Acer Aspire 5500 5570-2609 Laptop
Can not restarted after putting it to sleep
Acer aspire 5520G is plugged in directly to electricity via adapter try to restart it after putting it to sleep without luck, Unploughed it from power supply no good press ctrl alt del no good; any other ideas? Thank you very much! Mariyan
  • mariyan_t May 16, 2010
    I did pull the battery out and disconnected from power supply clean the dust ect.Nothing seams to work, but thank you very much for the thought.
  • 281 Answers
Pull the battery out, then back in and retry,
Look to see if you get a charging light when pluged in, if you dont then the power plug or power jack is bad and the battery cant charge
Posted on May 16, 2010
Graphic card problem
drive version is incompatible with windows 8, revert to your previous driver that used to work or is compatible with windows 8.
Dec 27, 2013 | Acer Computers & Internet
Tpm not found or tpm problem on acer aspire 5520g
solution is try to re install the Windows Vista back and see whether the TPM will show missing. sometimes thats happening to most of the systems. when you try to put another windows thats did not came with the product, you will miss some functions such as drivers, battery not charging, internet not working, audio not working and many more. so put back windows vista and whether your problem still existing.
Sep 08, 2012 | Acer Aspire 5520-5908 Notebook
Accidentally plugged a AC/DC adapter into the computer and when we realized it was not the correct charger we tried the correct charger and it will not turn on at all. Did I ruin the Acer aspire one...
Probably you provided more than enough power to the computer and it some of the fuses or capacitors are burned out. But maybe this is not the case. Try to remove the battery, remove the hard drive, remove the RAM. Put these parts and your laptop on the table. Avoid placing them on the carpet or blanket as these wil produ2e static electricity that damages computer chips. Leave your laptop in this state for about 30min. Recone the parts, put the right charger and restart your computer
Dec 18, 2011 | Acer Aspire One PC Notebook
I got my acer and the power light comes on but the screen is black
This happens with my Acer Laptop too. Make sure the computer is plugged in to a power source and try a forced restart. If that doesn't work, try using the sleep command to but the computer to sleep while the screen is black but the power is on. The computer's power light should shut down, and you should be able to go out of sleep mode by pressing spacebar.
May 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
In an aspire 5520G should the laptop boot without a battery inserted if plugged into power?
Yes it would turn on and boot. Take the battery out first. then plug in the AC adapter. turn the power on. You would be prompted that you are running AC power and no battery detected on most cases.
hope this helps.
Jul 12, 2010 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520g continuous restart on off problem
try cleaning the air vents with a hoover. worked for me mine kept overheating and shutting down it was down to dust
Mar 16, 2010 | Acer Aspire 5520-5908 Notebook
I have an acer 5735, the battery won't charge, sometimes it states plugged in charging, sometimes plugged in not charging, and sometimes fully charged, but in all cases it is not charged at all?
Hello
you can try this things
1st option
Remove your battery and check the pins if are bended or missing
2nd option
1- remove your battery
2- directly connect AC adapter
3- restart or on your laptop
4- after loading windows, put the battery
3rd option
Take battery out and use pencil erases to gently clean the contacts. Also clean contacts on laptop battery box.
Sometimes the contacts oxidize.
Then put back in and see if it charges.
if nothing of this worked,you will need a new battery
Jan 13, 2010 | Acer Aspire 5580 Notebook
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
