Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Need to connect the censors - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
The white wire from each sensor goes to terminal 2 and the white wire with black tracer go to terminal 3.
Posted on May 17, 2010
My fuel pump of my opel coarsa doesnt want to pump petrol and i have checked power on the socket is coming but i doent charge please help
Good day. A couple of things can cause your problem. First thing you can try is to connect a 12v supply to your fuelpump to see if its running. both positive and negative. There will be a positive supply present on the pump with ignition on. Its the negative wire thats being switched by a relay that is triggered by an electronic pulse censor. This censor works of a toothed gear on the front pulley. This censor also triggers the injectors as well as your spark. So if you have spark on the sparkplugs it means the censor is ok and that means your fuel relay is faulty. Most of the times its the fuel relay.
Jan 10, 2014 | Opel Corsa Cars & Trucks
Just dies, sometimes won't start. Changed crank shaft censor, still no good
ihave a 98 grnd chrk lrdo had to replace computer on fire wall, periodicly i spray all electrical connections w/ crs electric contact spray.
Jun 01, 2012 | 2000 Jeep Grand Cherokee
My middle button is not working it is stake
Most common problem of this phone is the censor or the navigator due to water damage or dropping the phone in high place etc.
Check this procedure :
* Remove the back cover of the your phone.
* Remove the battery.
* you can see a screw with a metal shield in the middle part. Unscrew the screw using a T6 precision screw driver and remove the metal cover.
* you will see a flex cable connected on the socket and that would be the censor or navigator we're looking for.
* check and clean the socket or connector with a solution or lighter fluid together with a cotton.also clean the socket of the censor. then put it back and assemble it then try if it's working.
If it's not working, then needs a censor replacement.you can buy to any parts dealer or distributor nearest you. this is so easy to do so you don't have to bring it to a mobile phone technician for replacement just to save service fee and discount on parts too..
Good luck and thank you for visiting fixya.
Jun 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
My washing machine is SANYO ASW-90WRTP. It cannot spin and showes E2 on the screen. I guess it means Error 2, but I don't know how to solve the problem. Thanks.
mungkin
  • barangkali
  • agaknya
  • ')" onmouseout="ht(this)">perhaps
    pintu
  • daun pintu
  • laluan
  • ')" onmouseout="ht(this)">door
    tidak ditutup
  • tak bersalut
  • ')" onmouseout="ht(this)">uncoated
    dengan betul')" onmouseout="ht(this)">properly or penapis
  • tapis
  • menapis
  • ')" onmouseout="ht(this)">censor
    in pintu
  • daun pintu
  • laluan
    gagal
  • kecewa
  • terkandas
  • ')" onmouseout="ht(this)">failed
    . menghubungkan
  • sambungkan
  • menyambung
  • ')" onmouseout="ht(this)">connect
    pendawaian')" onmouseout="ht(this)">wiring penapis
  • tapis
  • menapis
    with ( 2 dawai
  • wayar
  • kawat
  • ')" onmouseout="ht(this)">wire
    ) jika tiada
  • sekiranya tiada
  • sekiranya tidak
  • ')" onmouseout="ht(this)">if no
    dawai
  • wayar
  • kawat
    penapis
  • tapis
  • menapis
    menggunakan
  • penggunaan
  • gunakan
  • ')" onmouseout="ht(this)">use
    magnet
  • besi berani
  • batu berani
  • ')" onmouseout="ht(this)">magnet
    diletakkan pada')" onmouseout="ht(this)">placing at mengenai kawalan')" onmouseout="ht(this)">on control litar
  • lingkungan
  • peredaran
  • ')" onmouseout="ht(this)">circuit
    Nov 20, 2010 | Washing Machines
    1997 ponitac bonneville turn off after traveling a few miles
    Check the connector to the mass airflow censor...located just behind the air cleaner in the metal part of the throttle body.
    Start the car and wiggle the connector if it shuts off or stumbles the connection inside the mass air flow censor is faulty. Replace censor.
    Aug 02, 2009 | 1997 Pontiac Bonneville
    My '95 Bonneville is running rough and idling low and is shutting off and is very hard to crank
    This probably is the mass air flow censor located just behind the air cleaner in the metal part of the throttle body. Wiggle the connector if it stumbles or shuts off the connection inside the censor is bad. You will need to replace the censor.
    Jul 12, 2009 | 1995 Pontiac Bonneville
    O2 censor
    You would use an oxygen censor socket to repair that. You can buy one for pretty cheap or you can rent one from the parts house. You'll want to disconnect the electrical connection to the O2 censor, slip the socket over it (using the appropriate ratchet) and take it off. You can also use a 7/8 inch wrench on most cars if you can get it in there.
    Apr 27, 2009 | 1989 Ford Crown Victoria
    I need to know where you would locate a o2 censor and 2 map censors for a 2000 Pontiac Grand Am..V-6? I have no idea where to even begin looking on the car.
    The O2 sensors are found on the exhaust pipe. They screw into the pipe and has wires coming off of them. The MAP sensor has a 3 or 4 wire plug with a vacuum hose connected to it commonly found on the intake or firewall.
    Jul 10, 2008 | 2000 Pontiac Grand Am GT
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    42 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
