Question about Kenmore 63942 Dryer
Dryer door the dryer door keeps popping open while the dryer is running.
  • Kenmore Master
  • 3,740 Answers
The dryer door catch and latch assy is worn and needs to be replaced.
See this link to see which of them matches your dryer: http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Door-Latch-Kits/index.aspx
Any local appliance parts supply center will have this part in stock. It is howe3ver best that you take your "complete model number" with you when you go to get the replacement part. They are under $3.00 in
cost.
Use a knife blade to unlock the opposing plastic retaining tabs on the old part for removal. Make sure you change both pieces. The one in the chassis and the one in the door.
Thanks for using FixYa.
Kelly
Posted on May 16, 2010
Electrolux dryer eied50liwo door keeps popping open during drying
The latch mechanism is not fulling grabbing and the door pops open. By bending either the door mechanism or the chassis mechanism so parts are tighter you can restore proper operation.
Sep 04, 2015 | Electrolux Dryers
Dryer door pops open during cycle
Good Afternoon Friend,
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Jun 07, 2014 | Frigidaire Electric Dryer
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Door pops open
the one on the panel, but sometimes they sell you the whole kit. mind as well replace both
Oct 14, 2013 | Whirlpool GEW9250 Electric Dryer
My Kennmore Series 90 door keeps popping open so the dryer stops
Could be a defective door latch.
Could be an over-loaded dryer.
If you are not over loading,then replace the door latch.
Cost about 5 bucks.
May 08, 2011 | Kenmore 63942 Dryer
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
Jul 14, 2010 | Whirlpool ET8CHEXSQ Dryer
Maytag dryer pyet244ayw won't turn on
Most Likely bad fuse! (maybe caused by blocked vent)
Remove power! Unplug! Do not trust breaker!
Pop top, lift top from front (above door).
Heater is in back.
Thermostate on top of heater.
Fuse is beside heater.
Probably bad fuse! (Will read open on ohm meter if bad)
Next would be door switch (Will read open if door open, closed if door closed) Open all times will keep dryer from starting also.
Feb 16, 2010 | Maytag Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Jun 14, 2008 | Whirlpool Dryers
Kenmore 63942 Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
