My washing machine is only 6 or 7 mths old everything still working fine it just isnt spinning its still pumping water out though!
  • Rick Ead
    Rick Ead May 16, 2010
    top load washer or front load washer if its a top load check your drive couple whirlpool purposely makes the couple out of plastic the heavyier of a load you do the more apt this part is to break the new part has a metal ring around the shaft which prevents this from happening the drive couple is located behind the motor and in front of the transmission if you have a front laoder please specify which model you have
    Novelist:
  • 77 Answers
Chances are extremely good that you just have a broken coupler. These parts range from $15 - $25 on average. Were there any signs of foul play before this problem? Does your washer agitate(plastic fin in the middle rotate back and forth and wash the clothes)? Basically, if the coupler is broken, the machine with neither agitate or spin. However, you do not need a coupler to pump water out :)
I would definitely have it repaired. You should spend a little on the part + labor. Those are excellent washers and they do not make them anymore!
Posted on May 29, 2010
  • cramblock May 29, 2010
    I also assume that this is a KitchenAid machine. If this is something other than a top loading KitchenAid washer please disregard the advice ;)
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
I set my washing machine to run when I went to work. When I got home the dial looked as though it had run through the settings but the machine was still filled with water. Then I tried setting the dial...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 24, 2011 | Admiral Washing Machines
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Have GE GJSR2130 or
is this machine top loader or front loader
Mar 15, 2008 | Washing Machines
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
