Mitsubishi vs6041 no pic but audio works
I tried what you suggested, but i am unable to see anything on the screen to be able to tell if it is. please help. my cell #928-530-2731 thank's. carl
  • thekingsmith Apr 13, 2009
    I have an older 60 inch mitsubishi rear projection tv. It started were i would lose picture while watching,turn on and off a couple times would be ok, know lost picture but have sound any help please
    Genius:
  • 1,153 Answers
CHECK THE VALUE OF R509 AND R519 BOTH (100 OHM 1/2 W),LOCATED ON THE ON THE G2-P.C.B. PT#103P391030 2. (NO VERTICAL DEFLECTION) CHECK FOR 34V ON PIN 6 OF IC401,IF LOW OR MISSING.CHECK FOR OPEN L542 ON THE CATHODE OF D505.LOCATED ON THE MAIN-PCB. 3.CHECK FOR 2VDC AT PIN 4 IC401,IF MISSING CHECK IC9A2 (14 V REGULATOR), ON THE MAIN PCB. PART# 267P076010 4. CHECK FOR 34V ON PIN 6 OF IC401. IF LOW OR MISSING, CHECK R510 (.82 OHM 1/4 WATT) OFF PIN 5 OF THE FLYBACK ON THE MAIN PCB. 5. MAY BE INTERMITTENT. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES
Posted on Mar 31, 2008
  • Lashawn Robinson Mar 31, 2008
    More info goto ctechnicians.com and look for VS problems.
Hi, I have a vs6041 60". I have no picture, but all audio works fine. Please help.
hi friend
there was prooblem in video satge u have do do this get a tacnision to repair it u have chage curcuit bord ic so u have to take ur tv in a repeir shop then he chnge the ic & ur problem will solve
Mar 30, 2008 | Televison & Video
I have a vs6041 and need a remote code for it.
Almost any code for any mitsubishi set made over the last 15 years or more should work--if not a original remote being used it may have only some features needed.
Jun 12, 2012 | Mitsubishi WD-62526 Projection TV
NO AUDIO Mitsubishi TV Model WD65737
Sounds like the audio circuit portion of your tv went out. You could ask Mitsubishi for a list of authorized Mitsubishi service centers in your area. It may be expensive to have it shipped, but it might be cheaper than buying another one.
Dec 12, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Oct 15, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Jun 24, 2008 | Televison & Video
No sound after capture on computer
Can you tell my from the menu on the camera how you connected it to your computer?
Apr 02, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
No picture
If, in a dark room you can't even see the screen lit up, you have probably lost your high voltage driving the picture tubes and if the set is over 10 years old, I'm pretty certain that the parts will be no longer available -- that is one of my pet peeves about Mitsubishi. If you can see a grayish screen, then maybe there's a chance it could be repaired by a competent and dedicated technican.
Jan 13, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
