Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Miele dishwasher drying problem
Miele G646 plus dishwsher. On Turbothermic drying the fan appears to suffer water ingress and spits out water. When you open the door water runs out of the fan vent.
  • 5 more comments
  • lotus_2003 Apr 15, 2008
    I have problem with water ingress to Milele G7731. I have tried to check the floating sensor but I could not find it! Do you have other suggestions.
    Best regards
    Leo A
  • ChiefDJ May 26, 2008
    I have the same problem with my Miele G 848 in the last month (after 5 years).
    When the cycle is complete water will drain out the vent when the door is open - a half cup or so.
    Any solutions?
  • Touchscreen Jun 17, 2008
    We have a Meile G646 SC dishwasher which has the same problem. Again it is about 5 years old. Very annoying !
  • NIGUNDE Jul 12, 2008
    Have the same problem on a G847 SCI Plus but cannot find any solution
  • Anonymous Jul 14, 2008
    I have same problem exactly - 6 year old dishwasher. Hope the solution you posted works - I'm off to dismantle the door! Thanks
    Sue G
  • sloaneb Jul 15, 2008
    Ditto for all the below. We've taken to holding a cup under the fan/filter/whatever it is when we open the dishwasher door after a washing cycle has finished. Help!
  • Anonymous Mar 23, 2009
    I also have been having a very noisy and leaky vent. I followed the various pieces of advice and hopefully the problem will be solved.
    p.s. unscrewing the door of the dishwasher was easy - putting it all back together again was a pain.
  • 14 Answers
You need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
Great advice, one build on the G646SC Plus; the 4 screws are the lower 2 screws either, on the stainless steel inside of the door
Posted on Jan 02, 2010
    Novelist:
  • 269 Answers
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Posted on Jul 27, 2014
This post should see you sorted.
Posted on Apr 12, 2008
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
Miele g665 leaking water from turbothermic vent
I had this happen too. There is a rubber venting tube which runs from the vent on the door to the rinse/powder release pods. This clogs up and the water then comes out when the door opens. If you take off the front panel of the machine (screws are on the sides) it is easy to take off and clean out by running hot water through it, also clean out the line through the release pods .. problem should be solved.
Oct 21, 2011 | Miele 24 in. G665 Built-in Dishwasher
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
I need to replace the thin white door panel on a MIELE G832SC touchtronic turbothermic dishwasher
you want the replacement to be white as well? Check out ApplianceArt.com, they have over 200 different panel options including stainless steel, black, and white.
Nov 11, 2010 | Miele 24 in. G643Vi Plus Built-In...
The little vent above the words turbothermic plus is spitting out water during the cycle.
The fan assembly's drainage path is clogged. With time, food residue cloggs up the drainage path, inside the "Turbothermic" fan, and water accumulates during the drying cycle. The control panel, that houses the fan assembly, will need to be removed. Door panels will also need to come off. Unplug wires and drain hose to the fan, and loosen the round fan grill that secures the fan assembly (located inside the door). Take apart the fan assembly; unclogg drainage path and hose; and wash all parts. Re-assemble, install, and plug, the fan assembly, drain hose and door panels. Good Luck.
Oct 27, 2010 | Miele Premier-Plus Built-in Dishwasher
I have a Miele G 892 Dishwasher and recently the vent for the Turbotronic drying fan has been sticking in open position at the ned of the cycle. Teh result is the next cycle the vent fills with dirty water...
You'll have to take the door panel apart. There's a small drain hose between the turbothermic unit and the detergent dispenser. It's most likely clogged.
Feb 22, 2010 | Miele G880 Dishwasher
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
4,189 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
