Question about Panasonic Televison & Video
How do I perform panisonic projection tv convergence service? The remote works for all adjustments with the exception of the side to side alingnement of the blue on the # 3,6, and 9 positions, (or the top, middle,and bottom) on the right of the screen.The tv is 7-8 years old but other that it only needs to be cleaned internally.I am pretty good with electro-mech devices, but I have zero experiace with this?
  • j_gremlin May 17, 2010
    MODEL: PT-47WX53G
    Thank you!
    I would say bad."BIG BLUE GHOST" on the right.
  • 566 Answers
Hi jgremlin
I`m going to help you with your tv but first;
Could you give me the model number?
Posted on May 16, 2010
  • Jacques Marin
    Jacques Marin May 17, 2010
    o.k first; if you can`t bring the convergence back in like you used to, it means that there is a problem with that circuit.
    How bad is it: slightly off or bad?
  • Jacques Marin
    O.k this is repairable anyway.
    I`m going to give you a couple of web addresses where you will find what you need to do it yourself.
    One has the parts and instructions on how to do it and the other has the tools(recommended) needed to do it.
    For the parts: http://www.tvrepairkits.com/xcart/home.p...
    For the tools if you don`t have them: http://www.electronix.com/catalog/advanc...
    the both of them will cost you around a 100$ and there`s even a support line for the parts,
    In any case i`ll still be here to help you with it if you decide to go that way.
So the colours match up on the left hand side of the picture, and progressively fan out towards the right. The convergence had to be lined up manually for to come to this view. As well the picture has...
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Toshiba 50HDX82 50" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Need to converge the tv but dont have the original remote
you will need the origional remote. Yoou may be able to get one at the following link, just click the contact button and indicate the model number and what youre needing they ussually have them or can get them quickly.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | RCA R52WM24 52" HDTV Projection Television
Panisonic projection tv pt-53wx52f
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Oct 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magic focus, #5 Manual
Sounds like a Convergence IC problem, the convergence ics would need to be replaced. This can be done by yourself or a professional.
Jun 06, 2008 | Hitachi 57S500 57" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
