Question about HP Pavilion dv6000z Notebook
Won't makes a sound when pressing on keys. I
Won't type. makes a sound when pressing on keys. I change the speed to type . now it doesnt type at all
  • 281 Answers
You may need a new keyboard,, the beeping sound when pushing keys means there is a sticky key [bad keyboard]
I dont know what option you changed for the keyboard speed? try changing it back..
Posted on May 16, 2010
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
Key won't turn ignition on
If its a key with a electric code some time you have to have a new code key made any lock smith can do it there not cheep. I just paid $175 for mine to be done now it works great
Sep 09, 2012 | 2003 Land Rover Range Rover
The @ doesnt work when you press the key
It sounds as if your notebook is not setup correctly for either the right keyboard type or correct language.
As this is a new computer, I am assuming you are using Windows 7.
Click on Start then select the Control Panel - find the option shown below for Clock, Language, and Region, then Click on the option to Change keyboards or other input methods.. Next click on Change Keyboards, and finally ensure that you have the correct Language settings for where you are and the keyboard you are using.
If needed make any changes on this panel.
Jan 01, 2012 | Computers & Internet
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
My computer doesnt recognize my ego and the hard drive makes a buzzing/humming sound when plugged in.
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 15, 2011 | Iomega 34512 eGo USB 20 500GB Portable...
My laptop makes a continous beep sound and doesnt start till i do it by pressing esc key..?it doesnt start auomatically.
first you replace your ram or check it if on then oky if you have 3 beep then you have display problem you pulg the cable of moniter and press the key fn on change moniter display if display you lcd filament problem its change able if not display then your vga chip heat up so its not have proply solution
Dec 27, 2010 | Compaq Presario 700 470024-192 Notebook
How do you speed up the printing speed on a Paxar 9800/9850?
Press "escape"
Press Right arrow til display says "setup"
press "enter"
Display now says "supply"
press "enter"
right arrow til you see "speed"
press enter
adjust print speed IPS is "inches per second"
press enter after you change speed. hit escape key 3-4 times, then enter - you should see "print mode ready
If speed doesnt change it could be because the print speed is set by the software OR by the type of barcode you are printing. Serial barcodes default to 2.5 ips.
Apr 08, 2009 | Paxar Monarch 9825 Thermal Label Printer
The shop could not get the multi regional code for me until Monday to make the DVD player that i just bought multi regional the DVD player is code: DVP3252 do you hyave the code??? Could i have it...
i had the same problem mate, been through 3 dvd players on one day trying to get a region free player. i bought the dvp3252 and was assured it was region free, you just needed to change it. after 20 minutes of searching i found the answer on the internet so ill post it for you here, it works fine you just have to type the numbers on your remote at the right speed so dont panic if it doesnt work the first time
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Done.
Jul 18, 2008 | Televison & Video
Mercury sable 2004
Depends on the sound that it makes when you turn the key over.
Clicking noise...usually the starter
If it sounds like its going to start, but doesnt, most likely the battery.
If you have replaced the battery recently, then its the alternator.
Sometimes there can be oil build up over the spark plugs so it doesnt get the spark to start.
Hope you get it fixed!!
Jul 01, 2008 | 2004 Mercury Sable
HP Pavilion dv6000z Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
