Question about Kitchen Ranges
My new Miele touchtronic 1413 has been "drying" some towels for 5 hours! I don't feel any heat and the laundry room feels steamy. Can you suggest the problem and possible solution? Thank you.
  • theresa123@c May 16, 2010
    Thank you. I will have the contractor or installer check.
  • 600 Answers
I would start off checking the vent pipe, if it is dislodged or split it will do just that, it sucks in air from the laundry room, heats it to a set temp and blows it through the drum, of the warm damp air it escaping in to the room then it will take so, so long to not dry the shirts.
Posted on May 16, 2010
    Where do I find the vent to which you refer?
  • Chris Edwards
    Chris Edwards May 16, 2010
    it is a large flexable pipe coming from the rear of the dryer,
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
Miele T1515 - has started to make my laundry room feel like a sauna - why?
check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Sep 17, 2010 | Miele Novotronic T1515A Electric Dryer
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Sep 17, 2010 | Miele Dryers
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what...
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Aug 25, 2010 | Miele T9800 Electric Dryer
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Feb 16, 2010 | Miele W2203 Front Load Washer
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
The dryer is turned off and the door is open and there is still heat. I have to uplug the dryer in order for the heat to stop. We noticed this one morning, walking into our laundry room. (This was on...
I assume it is an electric dryer with 240 volt plug ? My guess is that it is the contacts in the motor start/relay switch that have welded themselves together and when the motor stops, the heat does not. This switch is located on the motor and it only allows the heat element to operate if the motor is running and creating the air flow. It is worth replacing. Goodluck, Macgivor
Jan 31, 2010 | Dryers
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
