Question about 2wire (1000-400108-001) Router
2wire ethernet port
How do i repair the 2wire ethernet port
Explain......
as far as i know 2 wire direct connects. try updating your ethernet driver
Posted on Jun 10, 2008
How can I hookup lan printer to the 2wire connection?
If the 2WIRE only has one Ethernet port, you're stuck, until you purchase a router, and connect the router to the 2WIRE, and connect your computer and your printer to 2 of the 4 ports on the router.
Sep 30, 2014 | Computers & Internet
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
How do i hardwire my desktop to 2wire
Behind the 2Wire you will find ports like LAN or Ethernet
Connect RJ45 cable between your 2Wire and the back panel of the computer tower (ethernet port)
Jan 13, 2010 | 2wire (1000-400108-001) Router
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Hi I cannot connect a NETLINK 2wire modem to my linkeye g router. What do I need to set so I can get the modem and router to connect
The 2WIRE modem will have at least 3 ports:
* AC power,
* 4-pin telephone-cable, connecting to a telephone-jack in a wall-port,
* 8-pin Ethernet-cable, connecting to the 'WAN' port on the LINKSYS router.
Look at both ends of the Ethernet cable. It's necessary that the colour-arrangement of the 8-wires is _IDENTICAL_ at both ends, i.e., a "straight-through" cable, NOT a "cross-over" cable.
With another "straight-through" Ethernet-cable, connect one of the LAN ports on the router to the network-adapter port on your computer.
Turn on the 2WIRE modem. Wait for the lamps on it to settle down to a repeating pattern.
Turn on the router. Wait for the lamps on it to settle down to a repeating pattern.
Turn on your computer. When Windows finishes booting, you should have a connection to the Internet.
Nov 27, 2009 | Patton Electric Patton NetLink MDSL Rocket...
Can't connect to Xbox 360
reset it...look at back side of modem.....
and if it not works then contact your isp ...
Aug 18, 2017 | 2wire HomePortal 1100 Router...
Unable to set 2wire wireless connection with my PC
connect a cable modem to it take out thwe existing ethernet in the cable modem put in the 1 that u have with ur new 1 put it in the cable modem put the other end in the first port of the ethernet ports take the 1 u took out of the cable modem and and it put it in 1 of the thernet ports all the light should go green then try wireless.
Feb 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
1 modem connected to 2 computers
Wireless is not the best thing to do heavy online gamming with. He he wants to keep a solid connection wile playing, ethernet is the way to go.
Feb 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
2wire (1000-400108-001) Router Logo
73 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
