Question about RCA P61927 61" Rear Projection Television
RCA 61 inches year 2003 Model # P61937 Need ballast board part # 12481311581202 Whats the price of the part and where can I find it I.m from Puerto rRco
  • RCA Master
  • 8,457 Answers
Tries these websites like Tvrepairworld.com,Tvrepairkits.com and Ebay.com to search and buy.Price are vary at each sites.
Posted on May 16, 2010
How do i find the ballast in rca dlp tv
I just had an issue with my rca hd61lpw42, I had replaced the lamp and got the same five blinks you described. I took out the ballast the smaller circuit board, its in front of the light and mounted to the front of the tv. To get to it you remove the back cover with the tv cooled down and unplugged of coarse. Be extremely careful when removing the ballast as it normally operates at about 336 volts dc. its basically no amps but it will still throw you across the living room. The being said I found another site that discussed our issue on the ballast going bad. It is not the whole board that is bad normally. There is a solder joint in the middle of the circuit board coming up off the bigger board and that solder joint normally goes bad and causes the issue. All I had to do was remove the board and resolder the connection and reinstall. But you can get them on ebay for $50. iif you have the money or no soldering experiance I would suggest that route. The site is http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313&_nkw=%09+RCA+Ballast+Assembly+%28261629%29&_sacat=0
Now I hope I can keep the light tunnel together :-)
Aug 10, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
Can i upgrade to high def on this tv model p61937
No,
You would need to purchase a new tv. TVs are either Hi-def, or they are not.
Mar 20, 2011 | RCA P61927 61" Rear Projection Television
I have an RCA P61937, and the picture is bowed and distorted....what can i do to fix this problem?? and how do i know what part i need
well look under power supply board around flyback. they have bad solder joints. it will then blow
the 400 ma fuse. just rtesolder the flyback and replace the 400 ma fuse beside flyback
Feb 15, 2011 | RCA P61927 61" Rear Projection Television
Rca model m61wh74syx1 is turning on with no pitcure and blinking 5 times then trying to restart
Hi,If your tv is around 1-2 yrs and haven't replaced the lamp it might be time to replace it.But if you hear clicking or continually trying to restart it could be your ballast ,which is the board that powers the lamp.The lamp you will need is the 270414 Found the lam pyou need here: http://www.discount-merchant.com/RCA-HD50LPW164-Original-OEM-Lamp-P-N-265866-p/rca-hd50lpw164-265866.htm?Click=48173 Good luck and God bless you!
Jan 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
Rca 61 inch not working properly
The vertical heigth is too high. whats the model number of your set?
Jun 12, 2008 | RCA D61W20 61" Rear Projection Television
61 ballast
You can get the ballast RCa part number 269043 at this link for 269.95. You have to leave an email stating what you want as they dont list all parts that they have at the warehouse, But I know they carry that ballast and they give free installation instructions with any part they sell. They will respond quickly with the info you need.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Rca scenium 61 inch dlp
the unit has a bad color wheel,a big pain in the ass to change.the part runs about 175.00 labor is about 200.Try first to get the manufacture to fix unit,be persistant
Mar 20, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA P61927 61" Rear Projection Television Logo
228 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
