Question about Dryers
Not heating to dry clothes - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 16, 2010
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Does not heat up when drying clothes
heating element is most likely shot.
good luck
please mark the post with a fixya
Feb 19, 2008 | Hoover Nextra HNWL 3126 Front Load Washer...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
