Question about Maytag MSD2756G Side by Side Refrigerator
Freezeor r works fine but frigerator not working
Freezer works well frigerator only at 60 degrees even on highest setting
  • 1,998 Answers
Check that your fan is working inside your freezer also check that u do not have an ice blockage problem if your fan is working and also check your t-stat and heater start with the fan if its not blowing the air into the fridge side then thats your problem you can order a new fan from marcone or allbrandsappliance hope this helps
Posted on May 16, 2010
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Freezer is staying around 20 degrees, refrigerator part working fine.
Check your freezer control and make sure its set at the middle point only, not on hi or the highest setting. This can cause your temp issues. Good Luck
Aug 31, 2014 | Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
I have a Whirlpool Princess series Model# ed20akxsn02 the Frige side is not cooling I have it on the highest setting getting 42 degrees and no cooler but the freezer is working fine?...
Check to see if the fan inside the freezer is working... Also check if you have any frost build-up inside the freezer ..Frost buildup is an indication of either a non working defroster and/or a bad fan. Can't diagnose it with limited information.
Regards'
Dectech
Feb 14, 2010 | Whirlpool Refrigerators
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
144 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
