Question about Gateway GMAX 5100 Computer Speakers
I do not have any volume out of the leftside front speaker
  • 3 Answers
I have the same speakers and the same problem. I ordered a new control module and one speaker has never worked with the new one as well. The control modules that came with these are faulty. Gateway should fix this for us, but I've had no satisfaction from them. Now they are so out of date that I doubt you could even find a new module.
Posted on Sep 19, 2012
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Rear speakers' volume of X-540 is too low. Maybe 20-30% of the front speakers. I'd like to increase the volume but it's already at max. I'd like to get the same output from the rear speakers as front...
In order to do this, your computer must be able to support 5.1 systems! Seeing as how a person wouldn't buy this particular set of speakers without knowing that information, I'm guessing you have a bit of knowledge under your belt. You need to go into your audio device settings on your computer and you should have the ability to tweak the settings of the rear speakers from your audio controller panel. I myself have the EAX which allows access to adjusting the speakers volumes based on distance from the listener!
Apr 13, 2011 | Logitech X-540 Computer Speakers
Left speaker sound is distorted can Ireplace one speaker
Yes, you can check left speaker by replacing it or by interchanging with the rightside speaker. If the speaker is okay, then check for faulty amplifier circuit board. Don't forget to check the dirty EP socket or banana pin for leftside speaker.
Sep 22, 2010 | Logitech Z-2300 Computer Speakers
Radio works. volume problems on drivers side front speaker
It sounds like the problem is with the speaker, not with the radio
Dec 04, 2009 | Cell Phones
SOLID AUDIO F-45 4CH 900W ONE OF THE FRONT CHANNELS ...
HI DUDE TRY TO CONNECT ONLY 2 PC OF UR 6x9 AT FRONT CHANNEL TRY IT OUT COZ IT MAYBE THE DONT HAVE MUCH POWER TO HIT VOLUME OR ELSE TAKE OUT UR SUB CONNECT TO FRONT CHANNEL OR CHECK UR SUB VOLUME .,...
Apr 01, 2009 | Solid Audio Formula Series F45 4-Channel...
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
FRONT SPEAKERS HAVE NO AUDIO AND REAR SPEAKERS IMEDIATELY FADE
check all your wires in the front speakers and make sure there coverd
Dec 06, 2008 | 1992 Mercedes-Benz 190
Open Questions:
Gateway GMAX 5100 Computer Speakers Logo
69 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
richie46
Raj Patel
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
