Question about Philips SHB6102 Bluetooth Headphones Headset
Can i use my shb6102 with my pc having bluetooth capability
  • 185 Answers
Yes actually you can use it the first time it will connect with no problem, just press and hold the on switch on your device and set your computer to find it.
The only problem and worst of all is that windows will not be able to download a correct driver for your device so you would have to find the right one, I have a motorola headset and it was a challenge. Do Not Update the Soleil bluetooth driver that will cause more harm; there is a great option that you can get from IBM lenovo their bluetooth driver and software is just great.
here is a link to the most actual SW:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70042
This will download the file 7zbv15ww.exe, save it and then run it, I'm using 7zbv14ww and it works great.
hope it works for you if it does don't forget to rate me
thx
Posted on May 16, 2010
Does installation of a wireless ouse reequire using a port?
It depends
What is required though is for the same capability to be supported by your PC.
If its bluetooth connected, the PC must also be bluetooth capable, if the PC is not you can always get a bluetooth adapter to make you PC bluetooth capable.
If its infrared, then you need to install the adapter that came with it, usually they come with a usb adater.
Aug 18, 2014 | Dell Computers & Internet
How if my Asus Eee PC 1215P there is no bluetooth but i want have it?
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 27, 2012 | ASUS Eee PC 1215P-MU17-RD Netbook
How to activate bluetooth on asus k55a
Dec 08, 2012 | Computers & Internet
Where will I find Blue tooth on lap top
You might have a function key you need to press or a button on the side or front of the laptop. Most times if the wireless is on and your laptop is bluetooth capable, then bluetooth is on.
You can always purchase and install a usb bluetooth adapter if your laptop is not bluetooth capable. Try Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type: USB Bluetooth Adapter in the white search box at the top of the webpage and click GO.
May 27, 2012 | Computers & Internet
Trying to connect bluetooth on laptop to phone blackberry curve 8330m
does the pc have have bluetooth or just capable? bolth bluetooth deviecs must be in receiving mode. download a bluetooth serial finder application matching your operating system. if that does not find the phone when in its in receiving mode u need to ensure pc has bluetooth card enabled w proper drivers!!!
Apr 25, 2010 | IBM ThinkPad T42 Notebook
Built-in Bluetooth does not work
have you used the bluetooth before? if not, check first with you manufacturer if your system has bluetooth device installed. bec it may be that your system is capable but it is just optional and needs to be ordered. then, update your bluetooth driver. also try a different device to connect to your pc via bluetooth.
Apr 05, 2010 | Computers & Internet
Toshiba satellite A35-S1592... Does it have bluetooth capability
I looked up the specs on the internet, and it doesn't have bluetooth capability. You would have to contact Toshiba or a repair shop to see if it can be added.
Mar 13, 2010 | Toshiba Satellite A35-S1592 Notebook
Does the satellite L25-S121 have bluetooth capability?
No, it does not have the bluetooth capabilities.
You can use a USB bluetooth adapter like the following
http://us.kensington.com/html/9403.html
Mar 10, 2010 | Toshiba Satellite L25-S121 Notebook
How can I transfer photos from Nokia cellphone to my PC
If its a bluetooth capable laptop, then just enable bluetooth on both devices and transfer files as you generally do.
If your laptop is not bluetooth capable, download the latest version of Nokia PC Suite compatible with your operating system from the official website of Nokia and synchronize files, any kind of files!
Simple!
Jan 23, 2010 | Microsoft Computers & Internet
Is the m275 bluetooth headset capable? & how would i pair it?
Standard spec doesn't show bluetoooth but if you have a bluetooth dongle yes it is possible but the Windows standard bluetooth driver doesn't do it. There is a better bluetooth driver available on the Toshiba website which works with many hardware devices.
Jun 26, 2009 | Gateway M275 Tablet PC
Philips SHB6102 Bluetooth Headphones Headset Logo
168 people viewed this question
Top Philips Radio Communications Experts
Nyte_Ryder
normis101
Tom Chichester
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
