Question about Frigidaire GLER642A Electric Dryer
My Frigidaire dryer model GLER642AS3 is not heating properly. I need up to 3 full cycles to dry the load. Any suggestions?.....Thanks.
    Problem Solver:
  • 17 Answers
If you have heat in the dryer, then its probably the venting blocked
Posted on May 16, 2010
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Frigidaire model# gler642as3
-You mean it work like normal but just no heat all ?
-If so check for heater element. It could be burn out.
Good luck
Mai
Dec 14, 2013 | Dryers
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
I have a frigidaire dryer gler642as3 model it ran for two hours and didn't stop also when you open the door during the cycle it shuts the drum off but the dryer gets very hot you can't touch it what can it...
Well the timer could be defective. But believe it or not a clogged dryer vent can do some of the same things. Without air flow, the heater will heat, then when it doesn't circulate and and dry clothes, it gets hot and the hi temp overload near heater should turn it off, then when it cools it will start the same cycle over. Make sure you have good air flow coming out of the vent outside. If in doubt disconnect hose from dryer. Make sure to remove any lint. Put a panty hose leg over the hose and try the dryer. If it heats ok now, then you know your vent is clogged (panty hose will keep lint from spraying allover your laundry room)
Oct 28, 2010 | Frigidaire Timer Knob
Friidaire Gallery Dryer, Model # GLER642AS3, S.S. # XD50808416 does not heat when in operation
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | Frigidaire Dryers
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
338 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
