Question about Kenmore Dryers
Gas dryer not heating, replaced ignitor and thermo-disk
    Problem Solver:
  • 17 Answers
If the ignitor is glowing and not lighting, you probably have bad valve coils.
Posted on May 16, 2010
Wont heat checked thermo fuse and ignighter both ok
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
My gas dryer starts up heating but after a few mintues it quits heating the drum. I checked the thermo fuse by bypassing it but doesnt mae a difference whats the problem?
heatman101';;
Feb 02, 2011 | Whirlpool LGB6300 Gas Dryer
Dryer runs for 20 minutes then blows cool air, if you let sit for 5 minutes it will blow hot air again but only for a few minutes. I replaced the thermo fuse, and the hi-limit thermostat. I just had the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag MDG308DAWW Gas Dryer
Need to know where the thermo coupler is and coil
if it is running its not your thermo i assure you
more than likely an ignitor
they are right up front once you take the front panal off
Oct 24, 2009 | Whirlpool LGN2000LWH Gas Dryer
Gas dryer no heat
There are many things it can be, does it ignite at all? do you get voltage to the igniter? whirlpoolpartssurplus.com open still give me a calll and we can talk for free..
Jun 24, 2009 | Kenmore 73952 Gas Dryer
Whirlpool dryer (no heat)
does the ignitor light up if it does check continuity on the thermo fuse (the little white one) if ok replace coils
Feb 19, 2009 | Whirlpool LGV4634JQ Gas Dryer
My kennmore gas dryer will not heat it spins and i turn the timer on and off and that works there is gas to the unit
unplug dryer , remove back panel and you will see a thermo link in about the middle of the back of dryer with a vom test continuity of the link this is a very common problem . if no continuity replace thermo kink . if it tests good remove access pane in front of dryer and turn the dryer on to a heat cycle, see if the ignitor coil gets red hot. if it doesn't then the ceramic coil is bad. these are the 2 most common problems with gas dryers. if still no good write back
Jan 26, 2009 | Dryers
Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Mar 12, 2008 | Dryers
Maytag Gas Dryer LDG7304AAE won't heat
Probably a high limit fuse. Check on the burner shroud for a 2 wire thermos. They should have little resistance. If so replace. If they are open, check for a restricted vent. Remove front panel and clean out area below filter.
Nov 12, 2007 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
