Question about Raymarine GPS
Goto functions disabled on Raymarine E80 (classic) chartplotter
I have a Raymarine E80 chartplotter, an S1 autopilot with an 8002 control head, a Raymarine 2kw radar scanner. Also connected to the sysem are a Raymarine Lifetag man overboard alarm, an S100 remote controller for the autopilot, an Icom AIS receiver, and various B&G Network instruments. At the beginning of an overnight passage the goto functions worked properly. I was able to set a waypoint and steer to it automatically as well as follow a route. During the night the goto functions ceased working. I can enter waypoints or build routes, but I cannot follow them. There does not seem to be an MOB point active, and there is no lead line from the ship icon to any waypoint. All other functions seem to perform normally. Does anyone have any idea what might be the cause or solution to this problem?
  • larry_lavers May 16, 2010
    I don't see how it can be the antenna, position data is received normally. New waypoints can be identified and placed on the chart. and i can determine course and distance to waypoints from the boat by placing the cursor over the waypont as it is displayed on the chartplotter. All functions other than goto and route follow are working. When i press the goto softkey, the new softkeys are grayed out, indicaing that they are not availale.
    The settings reset fixed the problem. Thank you. Now to reenter the custom configurations!
  • 12,061 Answers
" During the night the goto functions ceased working" (sic) Have you "Reset" this unit. This indeed sounds like a software problem, with either the MAPS, themselves, Or, the units Operating System & I wonder if a return to a reset state may not clear this "Glitch" ? Now if this doesn't clear it, then all one can really do, is reinstall the operating system, from either a CD/DVD or from the manufacturers website.
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=758&PRODUCT=1672
Your manual above.
Posted on May 16, 2010
    I have been trying to avoid a reset unless I am pretty sure it will clear the problem, as that will reverse a considerable amount of work in customizing the display. I don't believe I have the capability of saving my work. However, I seem to have run out of other options. I will try the reset.
  • 4,924 Answers
This seam to be a issue of antenna..it actually works but it do not receive any information to take a guide line and perform the actions..see maybe there are physical damages or something is obstructing ..the function ..
and cause it is such a vital function ...try what I sugested and ask for a second opinion if it doesn't seam to be this...just refuse my answer or ..vote under maximum..to get another opinion ...But it is pretty obvious that the issue is the communication with the satellite ..check the power on devices..also ...I mean external ones..
  • Catalin Turcu
    Catalin Turcu May 16, 2010
    I was under the impression that the functions are available but the points are not visible ..in this case is clear a issue from the software ..check under tools and see if it can be enabled..cause when a function is not highlighted its actually like you said disabled or not available ..also you can check the drivers for devices ..cause if a driver for a device used in a function is missing than the function will not be available ..so if you use them under a computer platform ..check on the device manager and see if any of the devices are in yellow with a ask sign ,,,this indicates a lack of drivers ..If you have any software related you can install (run them ) again ...when reinstalled all programs default themselves and usually all functions are restored..
I have an older ST4000 AutoPilot and this summer the drive motor doesn't seem to function. How do I disconnect the wires to determine if I have power coming from the control head and what voltage show I...
You can check it in 2 places:
1) the back of the control head
2) the motor itself. The wire plugs into the motor or the shaft coming off the wheel portion.
You should have approx. 12 VDC coming from the control head to the motor.
May 28, 2010 | Raymarine St 4000 Wheel Drive E12093
With the VHF on I can here the signal coming from the transponder, The orange indicator light soon changes to green pulsing gently. The E80 display unit displays ''No Data Source'' yet when the...
I would recommend upgrading the E80 and the DSM to the newest software levels:
E80 - 5.52
DSM - 4.12.
You can download the software off raymarine.com and load them onto different compact flash cards. Both softwares are upgraded through the E80 display.
Jan 29, 2010 | Raymarine St60 Plus Package, Includes...
When engaging autopilot on my twin Yamaha outboards, the engines atrt turning back and forth about 5 inches each way.What could be causing this.
Sounds like it is reacting too quickly. It is a good idea to do the system calibration again followed by the autolearn and see if that helps. Start with that.
Aug 14, 2009 | Raymarine St8002 S1 Smartpilot Autopilot...
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Feb 19, 2009 | Raymarine St8002 Smartpilot Autopilot...
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
GPS Logo
112 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
