Question about Philips 60PL9200D Projection Televisions
Picture not square
Om the left side of tv the colors over lap and the picture is kind of warped
  • Philips Master
  • 8,457 Answers
This tv have convergence problems.U must have soldering tools,solders,and know how to solders to solved convergence problems.U must change 2 STK convergence ICS,and some or all it resistors.Tries websites like TvrepairWorld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Posted on May 16, 2010
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Olympus om-1 i have had for 3 years and never got it out till now to take pictures up on stage of my grandchildren so really need a answer ASAP for tomorrow night what kind of film thanks and God Bless....
The OM-1 uses standard 35mm film. You can use black-and-white, color print, or color slide film. Color print film should be available at most drugstores. A good camera store will have all types of film.
May 25, 2012 | Olympus Photography
I am getting a warped 3d look at the top left side of screen and now am getting it also along the botttom of screen also. i am also having the tv kick out and the red on light blinks but when i go up to tv...
Tv have colors lines R,G,B mis alignment 3d picture.The tv convergence board it dead.The convergence board require changes 2 STK convergence ICS and some or all it resistors.The shop will cost u $300-350 for parts and labors.
Aug 25, 2010 | Hitachi 53UDX10B 53" Rear Projection...
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My jvc-hd52g886 has a bad picture where black shld appers it is over lapped with red bloches
A projection tv that has color issues is usually due to bad ballast which is attached to color wheel which you should also look at to make sure the colors are not mixed together and wheel is not warped.
May 10, 2009 | JVC Televison & Video
Picture double an inch from the left side
Your TV most likely has a convergence problem.
www.TvRepairKits.com
Nov 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Panasonic pt51sx60a ,bottom of picture bowed color has shadowy hues of blue ,occasional warping of picture ,hard to watch
my tv is panasonic pt-51hx41e hay can see picture but come on disturtion in tv ,they side that is mother board $380.00 hay need to now is true,or hay can buy part and ware?
Jul 30, 2008 | Televison & Video
Toshiba 40
Convergence amp ICs need replacing and quite possibly the resisors that power the IC as they usually burn open when the iC goes out. You will need two ICs. Let me know if you need any more info.
Feb 24, 2008 | Toshiba 40H80 40" Rear Projection...
Philips 60PL9200D Projection Televisions Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
