Question about Ryobi Cultivator
Starts but wont stay running like runs out fuel
Whats the routing on furel line does the fuel in line go to the carb or primmer bulb
  • 81 Answers
SOURCE: replaced gas line and primer bulb. cleaned carb,
If the engine dies when you try to speed it up chances are your muffler is the problem. Any equipment that uses a gas/oil will eventually have a stopped up muffler due to carbon buildup. This restricts the air flow and the engine won't run or open up. First take the muffler off and see if you can start and adjust the carb with it off. Turn both the air and the gas adjustment screws all the way in, then back them both out one and a quarter turns. Start from there.
Unstop the muffler by throwing it in an open fire for 10 to 15 mins or using a torch to burn the carbon out. There is a screen in the muffler that I would toss out (unless you live in California) for the only purpose it serves is catching carbon. Let the muffler cool on its own, don't cool with water or you will warp it and it won't seal right. Also while the muffler is off check the muffler port and scrape off any buildup there with a knife. Hope this helps.
Posted on Jun 19, 2009
  • 97 Answers
SOURCE: Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Posted on Mar 20, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: my ryobi weedeater has had a carb rebuild kit
As long as the fuel lines are not cracked or broken, then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek brush, (http://www.amazon.com/dp/B000V5MQ7Y/ref=asc_df_B000V5MQ7Y820727?smid=AKZ54EXMVZHXW&tag=dealt5228-20&linkCode=asn), to clean the small portals in the carb. Make sure the small screen in the carb. is free of debris. Reassemble and start. Let me know if you need further assistance.
Jim
Posted on Jun 11, 2009
TeleFurb
  • 16 Answers
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
Posted on Aug 25, 2009
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
My gas trimmer starts but wont stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
Internal line in gas tank came loose
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Fuel line routing for craftsman chainsaw 358.350370
Jan 11, 2012 | Garden
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
My trimmer came with no fuel lines connected to the primmer bulb. Does the longer nipple on the bulb get the line from the tank? What about the other nipple?
If your trimmer is brand new, you could take it back and receive another one that has the lines hooked up or go back where you bought it and LOOK at the same model and note the fuel lines routing.
Or you can try the fuel lines one way and if no success starting, switch them around and try to start the machine.
On these machines the "primer bulb" is actually a "puge" bulb that moves (pushes) air and old fuel out of the carb back into the fuel tank while drawing (pulls) fresh fuel from the tank into the carb.
Some lawn mowers have actual "primer" bulbs on their carbs.
Jun 09, 2010 | Garden
Fuel line routing help.
You should have one line (with filter) going to the carb inlet & one line going to the bulb then back to the tank.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Ryobi Cultivator Logo
42 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
