Question about Canon PIXMA iP6700D InkJet Photo Printer
Ink tank not recognized for MP510
The "black" ink tank is not being recognized, even after opening and closing it several times. This never happened before now.
  • 4,041 Answers
Hi there
Most IP-Tools will some times work for lots of printers.
Click Link = http://www.4all2sell.com/reset-tools/iPTool.exe
Click Link 2= http://www.4all2sell.com/reset-tools/iPTool.zip
Ones you have downloaded just double click on it to run it.
One of the files is in a WinZip format so if you not got WinZip on your PC you can download free from this Link = http://www.winzip.com/trialpay.htm
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: PineworksAll files on my website are only there for a limited time.
Posted on May 16, 2010
Mp510 waste ink needs emptying
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 22, 2013 | Canon PIXMA MP510 All-In-One InkJet...
The black ink is not printing on my canon mp510 even though there is ink.
sounds like the black ink jet is blocked with dried ink, use the maintaince tool, should be in the canon software
Sep 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
''The following ink tank cannot be recognised'' MP510
Try this to turn off ink level checking.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable ink level checking. The ink level checking doesn't always work well after a while and you can use this to refill your ink tanks as well.
Refilling ink tanks comes with its own risks and is known to not work well at higher altitudes above sea level. The closer to 4,000ft, roughly, the more likely the ink tank is to leak. And, these tanks can only be refilled about three times before the holes in the bubble jet corrode and are out of round. This will show as text that is not crisp to the eye in appearance.
Regards,
Worldvet
Nov 11, 2008 | Canon PIXMA MP510 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
New printer will not recognize the black ink cartridge
Some of the new machine includes only demo cartridges that is not full contain of ink on it. try to buy new cartridge and see what happen...
Oct 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  iP6700D InkJet Photo Printer Logo
266 people viewed this question
old marine
old marine
