Question about Polaroid i737 Digital Camera
When I take a pic it says card locked...
I have tried 2 dif memory cards they all say card is locked...I have also made sure the slide switch on the side isnt locked...
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Cyber shot camera dscw350 cannot take pics read only memory card
Look at your memory card or stick.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. Memory sticks have a slide switch just below the contacts. Slide the switch away from the "LOCK" position to unlock the memory stick.
May 17, 2012 | Sony Cybershot DSCW350 Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
"this memory card is locked" appears on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card and see what happens with that one.
May 13, 2011 | Panasonic Cameras
I just bought and installed (Window vista) a sony 2.0 (4GB) but the window is failling to format it because it indicating that it write protected.
Hi Thanks for you question.
Jan 25, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Memory card locked
Hi Thanks for your question.
Thank You for using FixYa.
Jan 16, 2011 | Canon PowerShot A520 Digital Camera
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
Memory card is write protected CoolPixS6000
Dec 29, 2010 | Nikon COOLPIX S6000 Digital Camera
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
Try to take a pic and says card protected
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 31, 2009 | Ricoh Caplio G3 Digital Camera
Camera Locked
Many times you need to format the memory card in order to use it... have you formatted the memory card? There's a menu on the camera to do this.
If you're using a card like an SD card, there's a very small slide switch that actually locks the card so no one can over write your pics. Find the slide switch and move it the other way, and that should unlock the card. You'll still have to format.
Mar 18, 2008 | HP Photosmart M425 Digital Camera
Polaroid i737 Digital Camera Logo
91 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
