Question about Cuisinart CMW-100 Microwave Oven
Our cuisinart cmw-100 still has the power sources and the timer illuminated. However, the microwave is not producing heat nor is the glass plate spinning at this point. do you have any suggestions?
Bad door switch, usually the top one. The switch costs < $2.00.
Posted on Sep 14, 2010
  • lenintjar783 Apr 28, 2011
    2.00 dollars very impresive, but where can we buy this switch, cuisinart wants the unit to be delivered to them so THEY can do the job and charge you an arm an a leg. besides no one seems to have this switch, thanks for your help i advance.
  • Faio
    Faio Jan 02, 2014
    Very easy, RadioShack or that kind of electronic store
Electronic buttons work, countdown timer, etc. But microwave is not warming
This is usually caused from a bad magnetron. Check the door switches first.
Nov 14, 2014 | Cuisinart CMW-100 Microwave Oven
Microwave is loud
It is normal to have a moderate sound, but if extremely loud it indicates trouble with the magnetron, should be returned for a replacement.
Apr 08, 2012 | Cuisinart CMW-100 Microwave Oven
Microwave lights up, timer works. No fan, no turning of turntable, no sound.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 14, 2011 | Cuisinart CMW-100 Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
I have the CWM 100 - the microwave is only about 1-1/2 years old. It runs, but the glass turntable no longer turns. No matter what we've tried, removing the glass plate, cleaning the wheels of the...
Check to make sure the Spindle that the plastic piece fits on is turning when the oven is on.
If the spindle turns, your problem is either the plastic wheel adapter is worn or not making proper contact with the spindle. You can replace th e adapter by going to Cuisinart.com.
If the Spindle is not turning, you can go to Cuisinart.com and find the nearest repair facility.
Nov 20, 2010 | Cuisinart CMW-100 Microwave Oven
Cuisinart CMW-100 , wont heat or turn the table? all else o.k.
We changed the 20amp fuse and that was not the problem so we returned it to Macy's. If anyone knows of a reliable brand of microwave today please let us know. All the reviews on microwave ovens recently are bad.
Jul 30, 2009 | Cuisinart CMW-100 Microwave Oven
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
654 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
noel
noel
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
