Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Clorinator cell is black
Cell hasn't been cleaned for a couple of months . i have used algicide in pool
  • Intex Master
  • 8,404 Answers
How much metal do you have in the pool water? Get it checked and if necessary, use a sequestering agent to remove the metal
Posted on May 16, 2010
What can I do for cloudy greenish water
make the priority fixing the water with an overdose of chlorine making sure to not use the pool for swimming while doing this, after the green goes, and you will know when you have put enough chlorine in when it clears up, then re adjust your pH level. after the level is correct, use the pool as normal .
Jun 10, 2013 | INTEX Sand Filter Pump
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
My remote shows aqua pure as a general default. I have cleaned cell but it did not change. System is not creating clorine.
In this case I would call the Jandy technical support. If it says it is in general fault then it means it will not generate chlorine. I hope this helps.
Aug 09, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Our system continues to give a 90 code reading even though we have a big enough filter pump to push enough water through the system. Everything is tight and the system is clean. how do we correct this...
Code 90 indicates that the water flow rate is not high enough for the system to operate properly. This is measured by a white plastic piece hinged from the top of the pipe. As water flows by the plastic piece gets pushed back and up against the top of the pipe so that it touches a sensor. A couple of solutions are as follows or a combination of these:
1) make sure that all pipes and filters are clean and clear. Leaves or other stuff will slow the water flow.
2) check that the clorinator is clear of any blockage or dirt.
3) unscrew the flow meter and pull out to check that the hinge is clean and the plastic piece moves freely.
4) when you put the flow meter back in place try turning it ever so slightly which might make a difference. This has worked sometimes for me.
5) make sure that the clorinator is level. I tilted my unit so that the inlet side is slightly higher than the outlet as an experiment and this works as well since I was trying to get the flow valve to travel less distance.(it's a geometry issue)
6) make sure there is no air stuck in the lines. Try lifting the pipes/tubes to move air out and make sure you bleed your pump to ensure that it is full of water and there is no air trapped here that would reduce flow.
7) try taking any nozzle off the hose going into the pool. These may slow the flow coming into the pool and cause back pressure in the pipes.
8) I have a solar panel with a bypass valve. The clorinator only works when I run the water using the bypass valve so that no water runs through the solar panel. Try running all water only through clorinator with no other devices in line to slow the flow or produce any restrictions.
9) Try running the clorinator but take out the pump filter as an experiment. The filter may need replacing. Taking the filter out should tell you if this is the case if the clorinator works without the filter in place.
10) As a last resort check the flow rate requirements for the clorinator and on the pump you have. The pump may be undersized.
Jun 26, 2010 | Intex Automatic Salt Water System for ...
I have a salt water clorinator system can I use softwater salt instead of pool salt when I set up my pool
no you must use a 99% pool salt
The electro cells in a salt generator can not turn anything else into sanitizer ( chlorine )
Jun 21, 2010 | Intex Automatic Salt Water System for ...
Clorinator off no cell power.
"no power to cell" on my salt water chlorinator.
Mar 28, 2010 | Aqua Hayward Logic PS-16 Pool & Spa...
My water turns green when we shock it I have drained twice now Please help!!!
start with testing your chlorine and ph add liquid shock and conditioner to water dont use algecide you have to get clorine to open up this is critical ph clorine and conditioner you should get a good clorine reading or you have to add more shock
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Too much salt in pool (4,100)
the leslies employe is right the only way to get rid of the high salt level is to drain the water i would say drain a 3rd and fill pool and check salt level some salt genarators can not make chlorine at high salt levels or when the water is cold
May 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
110 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
