Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Fuser Replace Procedures
What is the procedure for replacing the fuser/fixing assy.
    New Friend:
  • 116 Answers
U its very difficult to replace fuser unit
Posted on Jun 14, 2010
Canon iR3225 is giving error code E000007-0000
there is a problem with the fuser fixing film...
you may follow the following procedures;
1. clean and re-oil the fuser fixing film, and
2. if the error persists, consider replacing the fuser fixing film
thanks
Mar 10, 2015 | Canon Office Equipment & Supplies
Error E000
Since you listed error code E000, I assume you are talking about a Canon copier. The fuser assembly failed to heat up and the code needs to be reset in service mode. If the code cannot be reset , you need a new fuser or parts for the fuser unit. Always list the Brand and model to receive the most complete answer.
Sep 03, 2014 | Office Equipment & Supplies
Error sc 543
fuser assy replace or have tech fix will need to reset code if you replace fuser assy
May 15, 2013 | Ricoh Aficio SP C311N Color Laser Printer
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Jan 31, 2011 | Kyocera FS-2000D Laser Printer
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
Fuser film has split so looking for part number of fuser film or fuser assy of canon L100 fax machine
FM2-3967-000 FIXING ***'Y FOR 120V, and
FM2-3968-000 FIXING ***'Y FOR 230V.
Best way is to replace whole unit, because of pressure, bushings,...
Jun 04, 2010 | Canon Office Equipment & Supplies
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Fuser / Fixing Assembly
Move the top back like you're going to replace the cartridge.  Then unscrew the control panel (one screw and it will kind of jiggle out).  Then unplug it and set the control panel aside.
Take all the left side panels off.
Look where the control panel was, and you'll see a hole where you can reach a long screw driver in and take out 2 screws.
On the other side, there's another screw that's not so easy to take out.  You'll probably have to get a stubby phillips screw driver, and then cut the handle off THAT.  Very difficult, but that's the last of the screws.
Unplug the three plugs, and jiggle the old fuser out.  Reverse the procedures to put the new one in.
Aug 21, 2007 | Canon imageCLASS D780 All-In-One Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
400 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
