Question about Dewalt Saws
How do i remove the blade from the saw - Dewalt Saws
    Scholar:
  • 130 Answers
Make sure this unit is NOT plugged in. The blade needs to be in a lock position to loosen the blade nut. Most units have a safety pin that engages into the revolving portion. Once you locate this pin, press it in then SLOWLY rotate the blade by hand until you feel it engage. At this point the blade will no longer rotate. Keeping the blade locked, use your wrench and place it around the center nut and turn CLOCKWISE. The thread is left handed, so when startup the unit, the blade nut continuously tightens up.
Posted on May 16, 2010
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Remove blade from master force saws all
  • 1. Disconnect the saw from the power supply.
  • 2. Open the blade-clamp release lever.
  • 3. Insert the saw blade into the blade clamp as far as it will go, and release the blade-clamp release lever to lock the blade in position.
  • 4. To remove the blade, open the blade clamp release lever and pull the blade from the clamp
Blade cannot be removed Saw dust in the clamp slot
Clean the clamp slot with brush
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=masterforce+saws+manual
Dec 09, 2015 | Saws
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
Instructions on removing blade from jig saw model dw933
To remove a blade on this saw, lift the knob on the top of the saw and rotate the knob counterclockwise. This will open the blade clamp. The blade should slide out. To install a blade, slide a blade in, being sure the back of the blade fit against the support roller. Clamp the blade in place by turning the knob on top of the saw clockwise until you hear a clicking sound, then push the knob down.
Hope this helps.
Apr 26, 2011 | Garden
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Oct 02, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
How do you unlock the blade to use
Unplug the saw! Some saw have a blade locking button on the side of the motor. Others have a hole in the saw blade. Either push in the locking button or stick a ice pick into the saw hold to prevent the saw from turning. Use a open end wrench to remove the nut holding the blade to the shaft. Some nuts turn right to remove!
Jun 12, 2009 | Saws
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
Saws Logo
351 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
