Question about Ovens
Repair chipped enamel coating on bottom of oven
Repair chipped enamel coating in bottom of oven, at inside front door edge. The colour is standard dark brown. Oven is Whirlpool.
Rotu
  • 175 Answers
SOURCE: Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Posted on Jan 13, 2007
vest6
  • 196 Answers
SOURCE: Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Posted on Jan 26, 2008
  • 8 Answers
SOURCE: chipped the porcelain or enamel off
yes they have almond , white, black repair paint used to get from walmart maybe not anymore i dont repair anymore but they do have it . it smells really bad an takes a long time to dry careful of over spray also getting on other parts of stove top
Posted on Oct 11, 2008
aborcass
  • 2651 Answers
SOURCE: Enamel chipping
the interior of the oven cavity is chipping??? if so not a worry or concern for saftey or health concerns stictly cosemetic
Posted on Nov 13, 2008
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
The enamel on the bottom of my oven has started to flake can i buy paint to repair it before it goes rusty
You can buy enamel paint , depends where the rust is, you can buy heat proof paint if it is inside the oven.
If it is outside then treat it with a rust inhibitng paint first.
Nov 09, 2010 | Ovens
Enamelware repair
I have used appliance touch up paint to repair scratches and chips on ovens on enemel with out any problems.
I do not think you will have a problem
I do believe that there is a specific touch up for white enamel, but I don't know about other colours
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Oct 10, 2009 | Ovens
I need to repair the enamel in the base of my oven. It has been removed in somne areas.
they make special appliance enamel touch up paint, which is good for a knick and a chip here and there. If its a bigger job than that, you may want to use a higher heat enamel. Ive used high heat engine enamel purchased at an auto parts store, which they formulate to work with the heat of car engines. It comes in a spray can, so it depends on the scope of the project/repair.
Aug 31, 2009 | Philips Ovens
Melted aluminum foil on oven floor
I'm not up on my science, but..it's like welding, or more like soldering, chances are it's a high temp metallic enamel paint, and the two fused creating a mechanical bond. Your stove is cooked. You may be able to scuff the bottom and repaint it with a new coat of high temp enamel.
Just remove the racks, undo the clips that retain the heating element,(so you can lift it some, DO NOT try to remove it) tape off the bottom to create nice clean edges, using a piece of 80 grit sandpaper scuff the paint really good, lay down a coat of primer if the directions call for it, and follow the directions on the can. Don't worry about the clips, close the door and turn the stove on to the temperature specified on the can, and leave it on for the time stated. It will bake to a smooth glossy finish.
Most of the products I've used go up to 1000 degrees, and bake at 400 for 4 hours.
Good Luck!!
Thanks
Aug 23, 2009 | Kenmore Ovens
Clean glass range door
Hello. I recommend a product called Cameo. Cameo is a non abrasive cleanser actually designed for the new type enameled sinks recomended by American Standard. AND iit works great on oven door glass. You can get it at Walmart. Very inexpensive and works great on all kinds of surfaces that may be hard to clean but you don't want a harsh cleaner that might damage the surface or scratch. Has a very light to almost none scent. Very good for cleaning the oven both inside and out. Doesn't have the chemical smell left by some cleaners that can be intensified by heat.
Aug 14, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
How best to clean neff U1320 oven
The door itself is vitrous enamel, although I have not found it a problem if some gets on to it.
What you must ensure is that you do not put any on the element liners or covers on the sides. of the oven, otherwise it stains them.
Don't get it on any paint work either.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Ovens
Enamel chipping
Nov 12, 2008 | Ovens
Chipped the porcelain or enamel off
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
325 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
