Recently my Western Dig. 40gb hard drive went dead I have another just like it that I installed now it won't boot up.it says (drive not ready -system halted) Do I need to use the jumper or not?Also what connector do I use on the 80 pin the very end OR? HELP
  • 86 Answers
Use the cable select jumper setting, you'll need to reintall your OS on the drive before it is able to boot.
Posted on May 16, 2010
Computer is dead, need access to hard drive content
your best bet would be to goto ebay and buy a kit which turns your hardrive into an external drive ..... determine what kind of hard drive it is and buy a kit .... ide or sata etc either way you will need to buy the coverter
Mar 29, 2014 | Western Digital Computers & Internet
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Replaced a crashing hard drive that worked a day, now it doesn't
Power supply blocks do weird things. If you can beg borrow or... a power block for your computer (500 watt, eh?), try that before you upend the computer. A power block has fixed MANY issues for me.
Is it possible to test the hard drive on a friend's computer? The store that sold the hard drive can likely test it for you, perhaps for nothing.
It sounds like you may be having a problem with the hard drive interface on the mother board. Try using the second interface. It is very unusual for a modern computer to be unable to detect a hard drive. You HAVE tried a new EIDE cable, right? 80 pin? Place the drive selector in the neutral position (no selection).
Mar 22, 2010 | Western Digital Computers & Internet
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
1TB Western Digital External keeping system from booting up
You need to go into the BIOS of your computer and change the boot order of your computer.  Your computer must be set to boot from your main hard drive only.
Mar 05, 2009 | Western Digital My Book Essential 1TB...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Booting Problems When Western Dig. USB Hard drive is Connected
Your laptop will be set to "boot from USB first" in the BIOS. Go into the BIOS (F2, F10 or DEL key as stated on startup) and look for the boot order options.
Change it to boot from the internal hard disk first and all will be sorted.
Feb 06, 2009 | Acer Aspire 5100 Notebook
Hard drive
jamesroland1,
You have a computer with a 40GB hard drive and you want to add another hard drive (150GB), is that correct? Not knowing the rest of your system age, setup and configuration makes it hard to know what you may encounter. If you can add more memory (RAM) it is always helpful to make applications work faster and multiple ones as well. You may want to add an external hard drive if you don't have the room or don't feel comfortable with opening the computer and installing an internal hard drive. If you want to replace the lower capacity drive, you need to reinstall the operating system on the drive and start from scratch.
randy320sgi
Jan 18, 2009 | Western Digital (WD1500ADFD) 150 GB Hard...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
