Question about Breville ESP8XL Espresso Machine
Water does not heat up
Theh machine works perfectly on every other aspect except that the water doesn't heat up. Where can I get it repaired in Montreal, Quebec, Canada
  • 4 Answers
I found another entry online that mentioned that the Breville esp8xl has a connector to the heat chamber that corrodes and can become loose. Sure enough, my Breville esp8xl was fixed by opening it up--from the bottom, 8 screws on bottom, then two screws into the top from near the front, two at the back, and one under the lid, finding the blue wire with the loose connection, tightening the connection, and voila! my machine works like new.
Posted on Jun 09, 2012
  • Breville Master
  • 1,711 Answers
The machine have a puss button used a reset for safety thermostat. If the machine went overheated for any reason then you have to push this button once all the way in and the machine will probably start heating again. If you try the above but you have not any heating then the heating elenet need to be replaced. Their is a very small posibility that the electrical wirring in a point to be oevrheated and lost contact so in this case you need to replace connector.
Posted on May 16, 2010
II have a Breville esp8xl that does not put out any steam or water to make the coffee. when I switch it to steam it makes this tug tug tug noise and when switched to make coffee it will make a sound as if it brewing but again nothing comes out.The top of the of machine is hot at lease I know.
Posted on Jun 04, 2010
  • xtianlisa Dec 25, 2010
    I have the same problem. Any answers???
  • kristaw_26
    kristaw_26 Aug 23, 2012
    i have the same problem
How do I fix a Tumble drier which does not heat up please?
you will have to replace the heating element
Sep 27, 2015 | Dryers
Works perfect except won't cook heat
U gotta turn up the wattage..
Apr 06, 2013 | Microwave Ovens
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
My microwave appears to work in all aspects except the important one, it is not heating. It is 7 years old. Is this repairable or does it need replaced?
probably a blown fuse. i would not suggest fixing yourself as there are extremely dangerous voltages inside. to have service shop fix would cost 80 to 100,m prob best to toss and buy new.
Oct 18, 2010 | Vacuums
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
Hi - my machine works perfect except that it has
I posted this same solution for another inquiry but I will state it again in case you can't find it. I tried everything as well to try and get my machine (only used twice) to **** up the dirty water and I couldnt' fix the problem - there was no suction at all. Then I discovered there is a tiny (about 1 inch square) red plastic filter that is in the removable section that has the round dial to switch from floor to tool. As I said, it is a small red plastic square and there is a little door on it. If you flip it open (It actually looks like it can be removed) you will probably find a bunch of hair or carpet fluff. Mine was completely blocked. Remove the stuff and your machine should now **** up the water perfectly. I hope this helps - it took me a long time to figure this thing out!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water does not heat up
my sugestion is that you buy a new heater cost less than to repair the old one.goodluck.
Mar 29, 2007 | Saeco Vienna SuperAutomatica Coffee...
Breville ESP8XL Espresso Machine Logo
953 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
