Question about Toro Lawn Mower With Toro Power Tools
I have a timecutter 4200 and the mower cut off and i cannot get a spark.
First thing to do is change the spark plug. If you still don't get spark then remove the stop wire from the coil and see if you get spark. If still no spark, replace the plug wire and coil. Click on the link below to read more
http://www.fixya.com/support/t1953500-toro_timecutter_z4200_will_not_start
Posted on May 16, 2010
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Why does motor try to stall after cutting for 30 or more minutes? Acts like it is running out of gas but has full tank.
check your gas cap
then check the fuel lines, if they are soft or spongy, replace
then check for spark
in this order
Aug 20, 2014 | Toro Zero Turn TimeCutter SS Series SS5000...
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Engine wont start
Make sure wire from battery to starter is connected and there are no problems with wire ( I.e. no missing insulation, cuts and connection to starter is secure.) Also starter may be bad.
Apr 19, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Toro 4200 time cutter stalls when the handles are pulled in
I believe the timecutter has a safety switch that only allows the unit to start with handles in the out position, then you need to be on the seat to be able to pull handles in without stalling engine. Have you tried checking the seat switch? It sounds like one of your safety switches isn't working. Either the seat switch or the handle switches. That's where I would look first. Good luck!
Oct 24, 2013 | Briggs & Stratton Briggs Stratton...
Starts, runs and when handles are in gaged moves forward then stops and kills the engine.
Sounds like a failsafe switch or sensor is causing this issue. I would have the seat switch checked to see if it is causing the cut off issue.
Sep 24, 2013 | Toro TimeCutter MX4260 42" 23HP Lawn Mower...
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro Lawn Mower With Toro Power Tools Logo
146 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
