Question about Kenmore 43142 Front Load Washer
Kenmore washer front loader is making banging noises and it does not seem to clear out water. Any ideas what might be causing this.
  • Anonymous Apr 16, 2009
    Yes i have the same problem. This is the second time this has happend to me within 6 years of owning this thing. My only solution to fix this problem is to make my own out of stainless steel like it should have been originally.
  • dgulley May 11, 2010
    It's the rear support on the back of the Stainless steel tub. It's caused by dissimilar metals in contact with each other.(GALVANONIC CORROSION) I'm fighting with sears at the moment to get a replacement. There is a 25 yr warranty on the tub against rust , but they say the bracket is not covered, but here's the kick in the face.YOU CAN'T BUY THE BRACKET SEPARATE because there's no part # for it , it falls under the tub part #...So I say it's all one part so it has to be covered under the 25yr warranty.. Now if they do give you one under warrenty they have to install it, but that will cost more than the part .....I'm at my witts end, I have a 7 yr old machine that probably won't last 3 more yrs that I have to sink $500.00 dollors into to get fixed under warrenty.... WAY TO GO SEARS !!!!!!!
Check springs that the drum hangs from and supports that help hold it up. I replaced a shock absorber and a spring myself and I am a woman with fibromyalgia. Not a hard fix. Take of the back panel and there should be two springs hanging from the top and two shock absorbers supporting the drum from the bottom. Grab them and make sure they are completely attached. Then call your local Maytag or Sears for parts. When the washer is off balance it wont spin or will not spin enough. When these parts go out it will bang around. More that likely it is the shock absorbers from the bottom. Good Luck
Posted on Aug 03, 2008
  • 172 Answers
Hi Benson5,
you could possible have something in your pump. You can clean it out by removing the bottom panel to expose the pump and unscrew the pump filter. Be sure to have some towels and a pan ready to catch some water. If that does not solve the problem you may have either a cracked tub support or something between the inner and outer tubs. Both are major repairs that take several hours to perform. So lets keep our fingers crossed that its just a little something in that pump. Lots of luck to you, and I hope this helps you. Mike Anderson mca0824@aol.com
Posted on May 02, 2008
Most likely the inner tub support is broken. I have replaced mying once the whole assmbly was available from Sears for $150.00. However, I was in today to get my second replacement and Sears informed me they will not sell the replacement to customers only authorized Sears repair personel. I am going to call customer service on Monday. If I do not get the part there will be one less Sears customer in the world. Bottom line it is poorly built and Frigidaire (who makes the washer) and Sears need to stand behind their product.
Posted on Aug 10, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 16, 2011 | Kenmore Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Dec 29, 2007 | Washing Machines
Kenmore 43142 Front Load Washer Logo
216 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
